Throttle Position Sensor
.............How the %^& do you get the TPS off of an old throttle body. And attach it to your existing throttle body, if there are no bolt heads, as to which you could apply leverage to get it off? or do you just have to buy a new throttle body? Any help would be really great.
You can use a dremel and cut into the rivits enough so that you can get a flat tip screwdriver in there and then just unscrew them. Then just use screws to secure it to the new throttle body. Don't forget to set it though.
smash
smash
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smash fascism »</TD></TR><TR><TD CLASS="quote">You can use a dremel and cut into the rivits enough so that you can get a flat tip screwdriver in there and then just unscrew them. Then just use screws to secure it to the new throttle body. Don't forget to set it though.
smash</TD></TR></TABLE>
when you set it, use the Helms manual to find out which wires to probe with your volt meter.
had to do the same thing with mine. just went to the salvage yard and picked up a few in case one was bad. but i also have a connection so it didnt cost me anything..... good luck.
ek_99_SiR
Jul 19, 2005 09:34 PM
