Starter and Alternator Compatibility: D-series to B-series
Old Feb 17, 2002 | 12:09 PM
asnx6pac's Avatar
Default Starter and Alternator Compatibility: D-series to B-series
Does anyone know if a starter from a 92-95 D16Z6 will work with a YS1 tranny and if a alternator from a D16Z6 will work on a 90-93 b18a?
Old Feb 17, 2002 | 12:37 PM
SHo X dragger's Avatar
Default Re: Starter and Alternator Compatibility: D-series to B-series (asnx6pac)
i dunno about the starter- but the alternator WILL NOT fit no matter what anyone says- save yourself some hassel and buy the correct one
Old Feb 17, 2002 | 02:08 PM
KS-R's Avatar
Default Re: Starter and Alternator Compatibility: D-series to B-series (SHo X dragger)
I've used a 94 GSR alternator on an D15 motor. So you might be able to get the alternator to work.
Old Feb 17, 2002 | 07:28 PM
asnx6pac's Avatar
Default Re: Starter and Alternator Compatibility: D-series to B-series (KS-R)
Did it bolt up right? Or did you have to fabricate a mount for it? What belt did you use?
Old Feb 18, 2002 | 06:58 AM
-TJ's Avatar
-TJ
The Alternator WILL WORK B on D or D on B, whatever.
On Civic/CRX/integra's the easiest way to differentiate alternators is by 3 rib pulley or 4 rib pulley. NOT by motor code. Example: B series alternators (4 rib) are the same as 92+ D series (also 4-rib).
You cannot put a 3-rib pulley on a 4-rib alt. or vice versa. The alt. shafts are different sizes (I tried once).
Also, a difference between them is the mounting ear location, although with the right belt it's not an issue.
That said, rest easy knowing I've always run a SOHC D Alternator on my B16A for pulley-frame clearance. I'm using a 760mm (3 rib) belt, part number 31110-PM5-A110.
I'm also using a 4-rib alt. on my SOHC D16A6 to maximize blower belt grip and to take advantage of the 92+ crank pulley (boost).
The starters are different.
-TJ
Speedra500
Jul 10, 2006 07:30 AM
jaydm ferio
Jan 14, 2005 05:37 PM
2muchPSI
Mar 20, 2003 04:43 AM
kenji
Nov 17, 2002 08:17 AM
