quick question about brakes on 99 lx accord
Old Jul 17, 2005 | 03:27 PM
HondaGuy02's Avatar
Banned
Default quick question about brakes on 99 lx accord
alright, so this girl wants me to change her brakes on her 99 lx accord. I just want to make sure i know what im getting into before im in over my head. First things first, im use to changing integra/civic brakes so how are these accord brakes different? I have done a 95 accord and that was somewhat annoying compared to my integra which is cake.
So i guess i want to know how different the brakes are then my 94 integra.... and also im assuming its all wheel disc??? but again.. not 100% sure.
thanks for the help guys, just tryin to make a buck
Old Jul 17, 2005 | 03:31 PM
dew80362's Avatar
Default Re: quick question about brakes on 99 lx accord (HondaGuy02)
Its easy don't sweat it. If you've done any brakes before you won't have a problem with these. If she has drums on the rear you should need to do anything to them unless you want to clean, lube and adjust them.
Old Jul 17, 2005 | 03:40 PM
HondaGuy02's Avatar
Banned
Default Re: quick question about brakes on 99 lx accord (dew80362)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dew80362 &raquo;</TD></TR><TR><TD CLASS="quote">Its easy don't sweat it. If you've done any brakes before you won't have a problem with these. If she has drums on the rear you should need to do anything to them unless you want to clean, lube and adjust them.</TD></TR></TABLE>
So nothing tricky, rotors come directly off like an integras or a civics?
Old Jul 17, 2005 | 04:44 PM
HondaTechPro's Avatar
I would just replace the pads, unless the rotors have a pulsation or something, they are perfectly ok to reuse. In fact, if they look and feel good, and you replace them anyway, you might actually cause a brake pulsation. Honda recommends NOT machining rotors unless it is to remedy a pulsation. Honda also states that new rotors must be machines AFTER installation to ensure a true and parallel braking surface.
Old Jul 18, 2005 | 05:52 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaGuy02 &raquo;</TD></TR><TR><TD CLASS="quote">So nothing tricky, rotors come directly off like an integras or a civics?</TD></TR></TABLE>Beginning in 1998, the front rotors come off directly just like your Integra.
Since it's an Accord LX it should have rear drums (unless they've been swapped).
Old Jul 18, 2005 | 03:10 PM
HondaGuy02's Avatar
Banned
Default Re: quick question about brakes on 99 lx accord (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Beginning in 1998, the front rotors come off directly just like your Integra.
that means im only doin the front then
im cool off of the drums, ill stay away
TTIEQ
Mar 20, 2018 02:48 PM
gregh
Suspension & Brakes
Dec 14, 2009 05:36 PM
newhondaowner29
Jun 20, 2009 10:36 AM
poly35
Aug 3, 2007 06:57 AM
nfiniti
Oct 21, 2004 05:59 AM
