stinky H22 problem
Old Jul 17, 2005 | 03:12 PM
hdeuce's Avatar
Default stinky H22 problem
ive got an h22 in my 94 tegg and when im cruising with the windows down you can smell some nasty *** oil/gas smell. ppl say im puffin a lil black/blue smoke and got real low oil pres. need some opinions of what it might be. i think its my rings...havent done a compression test yet. idle gets real weird up, down, up, down.
Old Jul 17, 2005 | 03:36 PM
Chronic H22's Avatar
Default Re: stinky H22 problem (hdeuce)
when was the last time you changed your oil? Check your head gasket.
Old Jul 18, 2005 | 06:51 PM
negotiator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chronic H22 &raquo;</TD></TR><TR><TD CLASS="quote">when was the last time you changed your oil? Check your head gasket.</TD></TR></TABLE>
what he said. check all gaskets and if that isn't the problem you might have bad rings. either way, you are indeed burning oil.
Old Jul 18, 2005 | 07:47 PM
PrettyLude's Avatar
do a compression test
Old Jul 19, 2005 | 12:34 AM
WickedSol's Avatar
Default Re: (PrettyLude)
check your spark plugs, and since the plugs are out, check the compression, and do a leak down test...as for idle, IACV, dirty throttle body, vacuum leak somewhere on intake manifold...good luck!
Old Jul 19, 2005 | 08:31 AM
yOnKiNaToR's Avatar
Default Re: (SpdImge415)
you could be leaking oil and it's somehow hitting the exhaust causing it to burn and create that smell. you might also have an exhaust leak. check your header, exhaust piping, oil pan and all around the bottom of the block for oil that could be leaking.
ozh_hawaiian
19
Sep 12, 2010 06:54 PM
Specail Ed
Mar 10, 2009 12:39 PM
Kammy_Teg
Oct 11, 2008 02:14 PM
XLR8_HFX
Nov 8, 2006 12:04 PM
zexifiedlude
Sep 9, 2006 03:12 PM
