Cutting 1.5" Alum with a band saw possible???
Hey guys
I need to do some cutting not much say 1.5" thick about 2" long straight cuts can i do this on a band saw slow?? Ive seen alot of shops using band saws to cut steel and ****.
It cutting non-ferrous metals, the rule of thumb is to have between 3 and 6 teeth in the part at once. You only need a super course blade because you want to cut something really thick. You might be able to get away with a 10 TPI blade, but you will need to use wax lube to prevent clogging of the teeth.
Dont know if they sell "Delta" in the US. but they are cheap and work pretty good!
the more teeth the less the blade will 'bite' into the part. i bet 10tpi will work ok but is nowhere near ideal. take your time and lube it up!
