alternator belt broke...car wont start. battery fine
Old Jul 17, 2005 | 12:27 PM
sproket13's Avatar
Default alternator belt broke...car wont start. battery fine
well...last night..i was out driving, and my alternator belt broke. so i was trying to get it somewhere near home..when the car shut off with plenty battery life left! the car will crank, but nothings happening...i have spark in all 4 cylinders, fuel is being delivered..yet it wont start..not even 1 cylinder is firing? what could have gone wrong. it ran w/o a belt for a good minute or so, then it just died...any one have any ideas?
Old Jul 17, 2005 | 06:40 PM
sproket13's Avatar
Default Re: alternator belt broke...car wont start. battery fine (sproket13)
after 5 hours of tinkering with it...still cant find the problem..no one has ever had this happen to them?
Old Jul 17, 2005 | 08:50 PM
FortunateFool.'s Avatar
Sounds like a fuse to me. I blew my alt fuse a few times and same thing happened to me.
Old Jul 17, 2005 | 11:19 PM
Mike K's Avatar
Default Re: alternator belt broke...car wont start. battery fine (FortunateFool.)
check the battery fuse first.
then check the ecu fuse.
then pull your cap off and see if there's a dizzy problem.
Old Jul 18, 2005 | 08:17 AM
sproket13's Avatar
Default Re: alternator belt broke...car wont start. battery fine (Mike K)
i checked the distributor, everything looks good. i had my friend look at the fuses while i was checking other things, but he;s a domestic guy..ill have to look them over again, my timing belt has signs that somethign was rubbing on it just a little. im hoping that the alternator belt didnt get into the timing belt at the crank and throw it off wack. gonna check the fuses..and if i cant find nothing, its time to check the timing
Old Jul 18, 2005 | 08:53 AM
sproket13's Avatar
well..all fuses are good
Old Jul 20, 2005 | 05:38 PM
You check the unerhood fuses also ???
Old Jul 20, 2005 | 07:18 PM
sproket13's Avatar
yup...fixed the problem, im one lucky SOB...the engine is a b16 block, b18 head vortech supercharger...revs freely to 8700...head ported, crower cams valve springs retainers bla bla bla...10:1 compression. so i was kinda worried when this happened..hahaa! the alternator belt went through the timing case cover, and got sucked into the timing belt, the timing belt tore that mo F'er up and it wrapped around the cog, somehow timing jumped about 100 degrees. but luckly, no valve damage fixed everything up, changed all the belts, she runs fine now
Old Jul 20, 2005 | 07:57 PM
Damn id say lucky. I didnt even know it was possible to go 100º out of time lol . GL with it
Old Aug 12, 2024 | 05:52 AM
BrickJames's Avatar
I am getting sort of the same issue you had.. but many people telling me, it can be warn out piston rings, Clogged catilic converter or Timing, But seeing what your problem was... I'll check the timing of mine to see aswell.
youngturbo
Honda Civic (2001 - 2005)
Aug 10, 2010 06:28 PM
crx18c1
Apr 19, 2007 04:35 AM
vw eater
Dec 3, 2006 12:03 PM
crxgator
Jan 14, 2004 07:40 PM
