car starts for no longer than a second!
Old Jul 17, 2005 | 09:41 AM
blackie's Avatar
Default car starts for no longer than a second!
i just swapped a 99 gsr into a 99 ex civic. used the stock harness and a 99 gsr ecu. it cranked, and turned on for only a second! what could be wrong?
Old Jul 17, 2005 | 10:18 AM
blackie's Avatar
if i put some gas on it as it starts, itl rev up until i let go of the pedal
Old Jul 17, 2005 | 10:33 AM
bahraini civic's Avatar
check the fuel pump ................
Old Jul 17, 2005 | 10:36 AM
blackie's Avatar
anything else i can try while im at it?
Old Jul 17, 2005 | 10:39 AM
ZedEx's Avatar
Sounds like Fuel Pump... Or, it could be the same problem discuss in this topic.
Try that.
Old Jul 17, 2005 | 11:41 AM
8krdline's Avatar
Default Re: (ZedEx)
i had a similar problem before with a map sensor
Probably isn't the problem in your case, but wouldnt hurt to check.
Old Jul 17, 2005 | 11:48 AM
JDubbs99Civic's Avatar
Default Re: (8krdline)
sounds like you crossed your tps with your map sensor. they are both located on the intake manifold and they both have the same connectors. try that out first. keep us posted.
Old Jul 17, 2005 | 12:02 PM
blackie's Avatar
we put little things on them to let us know what plugs they were. the map sensor was one of the few we named.
Old Jul 17, 2005 | 01:37 PM
blackie's Avatar
when i do the swap using a usdm gsr motor with my stock 99 ex harness do i do nething to the ec pinouts? all we did was extend wires. for no i have to use a 99-00 si ecu till i get a hold of a gsr one.
Old Jul 17, 2005 | 02:45 PM
blackie's Avatar
bump
Old Jul 17, 2005 | 03:55 PM
blackie's Avatar
you guys think we cuold have gotten some plugs in the wrong places?. would not plugging up the o2 sensor be a prob? friend said his started atleast but threw a code but mine just isnt starting for more than a sec.
Old Jul 17, 2005 | 07:31 PM
ZedEx's Avatar
Why not check the ECU for what codes are being thrown.
Old Jul 17, 2005 | 07:36 PM
Luserkid's Avatar
Default Re: (ZedEx)
Check for codes then go from there.
It could be anything from fuel pump to IAC.
Old Jul 18, 2005 | 07:27 AM
blackie's Avatar
got it working!
Old Jul 18, 2005 | 08:02 AM
jerbear!'s Avatar
what was the problem?
mien_civic715
Aug 22, 2010 01:36 PM
its WANG yoO
Jun 11, 2007 02:54 PM
teamvirus
15
Aug 7, 2006 04:21 PM
Superdragr45
Dec 21, 2005 10:43 PM
turboHX
Dec 14, 2004 09:20 AM
