FS:95 CIVIC DX COUPE CHEAP RUNNING OR NOT NYC
Old Jul 17, 2005 | 08:19 AM
14bcoupe's Avatar
Default FS:95 CIVIC DX COUPE CHEAP RUNNING OR NOT NYC
-SOLD-
I have for sale a 1995 honda civic DX coupe 128k clean title
the car had the entire teggy swap removed from it so now it sits without a motor, i have the entire stock motor/tranny ect. which is the 1.5 E-vtec motor in perfect running condition. no grinds on the tranny either,all the mounts,axles,ecu ect are included.
i can sell the car with the motor already installed for $1700 or take the car with the motor and do the swap yourself $1100.
the mods for the car are the following ...............
-KYB GR-2 shocks with eibach Springs (cost me around 500 with installation)
-full 2.25 apexi cat back exhaust with resonator the muffler was removed in favor of a stock looking performance muffler so cops would stop bothering
-95 honda civic ex 5sp cluster with RPm and blue carbon fiber faces.
-replica type R shift boot and shift ****
-GSR front brakes setup, huge compare to the stock civic
along with the Type R 24mm sway bar with new bushings all around
makes the car handle like a champ around corners.
-brand spanking new lower ball joint no more than a month use.
-Rear lower strut bar and gold rear lower control arms with new bushings.
-99 Si sideskirts
-amber corners and black housing projectors
-entire A/C lines,compressor,fan ect will be included
PROBLEMS are the following.........
right side was side swiped but damaged cant be see if i take a picture of its really not bad. i purchased a new door for it same color as the car , but it was a power window door, so its not wired, so the window doesnt go down, all the wiring is there just needs to be wired, i have no idea how to. the front right side fender is also new but its primered black.
driver side window also doesnt go up all the way, you must finish pulling it up yourself manually, this is a easy fix 25 or less at any auto glass place.
no back seats are included, but i might get some this week since they are cheap as hell.
thats about it now on the pictures the car has rotas,leather seats,red/clear.
all those are not included stock 14" steelies were put on the front, has 2 stock civic seats, and stock rear tailights.
Modified by 14bcoupe at 10:05 PM 8/3/2005
Modified by 14bcoupe at 10:46 PM 9/6/2005
Old Jul 24, 2005 | 05:51 AM
14bcoupe's Avatar
Default Re: FS:95 CIVIC DX COUPE CHEAP RUNNING OR NOT NYC (14bcoupe)
ttt
Old Jul 28, 2005 | 08:50 AM
14bcoupe's Avatar
ttt
Old Jul 30, 2005 | 05:50 PM
14bcoupe's Avatar
ttt
Old Aug 3, 2005 | 06:05 PM
14bcoupe's Avatar
ttt
Old Aug 4, 2005 | 05:25 PM
MinorObsession's Avatar
pics of damaged side please
Old Aug 5, 2005 | 12:33 PM
14bcoupe's Avatar
Default Re: FS:95 CIVIC DX COUPE CHEAP RUNNING OR NOT NYC (MinorObsession)
Old Aug 5, 2005 | 12:37 PM
14bcoupe's Avatar
Old Aug 5, 2005 | 02:56 PM
Pm'd you man
rjmancia
Nov 7, 2008 11:41 PM
blackzrd
Jul 23, 2007 04:21 PM
Got Milk
Jan 22, 2007 02:41 PM
fasterthenmost
Sep 29, 2005 08:05 AM
14bcoupe
Jul 26, 2005 10:58 AM
