running new speaker wire in the doors?
Has anyone ran new speaker wire for the front speakers?
I am going to get the diamond hex component speakers for my fronts. I wanted to run a higher quality type of speaker wire
not sure if it can be done
From your bio, I can see you have a 95 gsr. It is pretty easy to run new high quality speaker wires into the doors.
(Briefly explained)
First: Carefully remove the door panels and mid woofer speakers.
Second: Pull out the rubber door boots by the hinges from their both ends.
Third: Remove kick panels.
After done all these, just need to fish and run through the boots the new wires from the back of the radio area, or from the amp, to the inside of the doors, voilá!
I hope it helped a little
(Briefly explained)
cruzeiro
Dec 17, 2008 08:26 PM
