eibach and the swap
Old Jul 17, 2005 | 07:56 AM
972drcordex's Avatar
Default eibach and the swap
Ok so Im getting ever so close to doing my h22 swap. My current suspension setup is eibach sportlines with kyb agx's. Should I be worried about my suspension, like does it need to be altered at all? Secondly un related to suspension does the h22, especially the header have clearence issues fitting in the accord or once its in? Lastly can I use my current worldsport exhaust system with the h22 and will the h22's header bolt right up to my current cat?
Old Jul 17, 2005 | 08:28 AM
fw190bvi's Avatar
Default Re: eibach and the swap (972drcordex)
you defninalty will want to run a wider diamerter cat on teh h22, especially if your running an aftermarket header. the h22 weights a little more than the f22, but it wont make an difference...mayve the front will be a fraction of an in lower, but thats not an issue at all
Old Jul 17, 2005 | 09:52 AM
Default Re: eibach and the swap (fw190bvi)
So I can use my current exhaust i just need to update the cat? But will everything line up right?
Old Jul 17, 2005 | 10:45 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 972drcordex &raquo;</TD></TR><TR><TD CLASS="quote">So I can use my current exhaust i just need to update the cat? But will everything line up right?</TD></TR></TABLE>
What gen accord do you have?
The cat won't be a problem, and neither will the cat-back. However, if you want to buy a wider cat, do it, but if you are tight on money you certainly do not need to replace for the H22 swap.
The only problem you will run into is that the H22 header is longer than the accord, and therefor you will need to cut and weld the header to the cat.
Old Jul 17, 2005 | 04:22 PM
Default Re: eibach and the swap (-Bionic-)
I have a 97 accord coupe. So is there any cat that will line up right and just bolt up to the header and exhaust and make there no need to weld. Id rather not weld the cat to the header.
Old Jul 17, 2005 | 08:56 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 972drcordex &raquo;</TD></TR><TR><TD CLASS="quote">I have a 97 accord coupe. So is there any cat that will line up right and just bolt up to the header and exhaust and make there no need to weld. Id rather not weld the cat to the header. </TD></TR></TABLE>
Well you can line the cat with the header and weld the back piece to the cat-back. Or, you can cut and weld a piece off of the cat-back.
jaysome01
May 12, 2009 08:34 AM
94BB4H23
Aug 4, 2008 11:33 PM
Knightmare69
Mar 14, 2006 12:49 PM
.jacob
12
Oct 31, 2003 06:38 PM
BigChris
Sep 18, 2003 04:49 PM
