Amber...err DEEEP RED gauges
pictures taken with a cell phone, all i had available, so it looks like crap. but you get the idea, the quality and darkness is perfect up front, no faded sides, all even and crisp red
REPLY (limted trial)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bauleycivic »</TD></TR><TR><TD CLASS="quote">Okay..?</TD></TR></TABLE>
i followed ur instructions and its great. just gotta do CC
Thanks to BauleyCivic for the write up
reply again (im limited so all i can do is edit)
Tech info.
I didnt actually buy new bulbs, ima cheapo, and i wanted a deaper red instead of an orange, so i took Red "Odds n ends" fast dry spray enamel paint to the bulbs. If you choose to use this paint you have to do about 3 or 4 coats, because if you dont you will get a pink cluster....
patients is a must of course, i tried it too quick, well got finger prints and smudged it had to start all over.
Something else i found out while doing this, those little blue rubber caps on the bulbs, they kinda melt to the bulbs, and are a pain to get off. i used a razor and carefully scraped away at it.
also, someone posted in bauley's thread about using LED's, well i went and bought 16 bucks worth of LED's. DONT USE THEM. They dont spread light evenly and you are left with gaps of darkness. im gonna see if best buy will take these back
if i had used the newer bulbs i bet this would have been alot brighter, however i dont like a bright cluster so i chose used bulbs.
Modified by 93egsedan at 9:41 AM 7/17/2005
Tech info.
patients is a must of course, i tried it too quick, well got finger prints and smudged it had to start all over.Something else i found out while doing this, those little blue rubber caps on the bulbs, they kinda melt to the bulbs, and are a pain to get off. i used a razor and carefully scraped away at it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Okay...?</TD></TR></TABLE>
I agrea why are you showing us this? this needs to have some tech in it before it gets moved or locked.
added a little tech info
a couple of donts, like using best buy LED!!!!!
sorry bout this, i just read the rules for this forum.
at the bottom it says something about people being to lazy to read forum rules...i guess i fall there. hope my tech info is enough if not. do what is necessary
Modified by 93egsedan at 8:27 AM 7/18/2005
a couple of donts, like using best buy LED!!!!!sorry bout this, i just read the rules for this forum.
