Air conditioning stop working!
My 91 Accord A/C system just dead!
I used it two day ago, cold and perfect! Today, I turn it on, no thing happen!
The A/C light is on but I did not feel the load of A/C compressor on the engine, the fan (condessor fan) was not running (but both will on if temp is up).
I checked all fuse -> GOOD! Now is the A/C clutch relay.
I researched the position of those relay an found that there are FIVE big relays just over the fuse box under the dask of the driver side.
Can anyone tell me which is the A/C clutch relay please ? Am I looking at the right place for it?
Also, how do I test those relay? If not the relay, what are other possilbility?
The temp is UP next week, no A/C is hell!
Thanks everyone!
Thanks everyone!
no no the a.c compressor relay is located on left fender next to condensor fan relay by the cruise control actuator the compressor relay has a red wire in it ,,but have you checked that you got freon in system ?? if no freon the compressor and the fans will not engage you might have a leak in a/c system i would chk that first before doing electrical chks
yeah just take the cap off and try and let a little out it looks like a valve stem on a tire if there isnt any in there you can try and recharge it but if it leaks out again you might as well give up on it because it will probably cost a butt load of money to fix
MikeRenna
Honda Civic (2006 - 2015)
May 23, 2019 12:22 PM
rr6jrggrj
Jun 14, 2014 04:37 AM
7rrivera7
Sep 16, 2006 05:19 PM
