Rough idle and won't Rev!
Old Jul 16, 2005 | 06:35 PM
Pete_SI's Avatar
Default Rough idle and won't Rev!
After changing the engine in a 1995 SI (EX for you guys) the car doesn't idle very and doesn't rev past 2500rpm. The things that surpises me is that I don't have any CEL. I would like to have people's experience with this. Plugs..Bad grounds?
Old Jul 16, 2005 | 09:39 PM
Pete_SI's Avatar
Default Re: Rough idle and won't Rev! (Pete_SI)
Old Jul 16, 2005 | 09:48 PM
Ignitecivic's Avatar
when u rev, does the car sounds like its going to die out.
my friend just had the same problem today. we could rev it high if only we tap on the gas slightly, but when we floor it, it feels like it going to stall
we change out the dizzy cap and clean the dizzy with a rag.
problem solved!!
Old Jul 17, 2005 | 02:05 AM
underb00steg6's Avatar
sounds like it could be the dizzy....or check your fuel ....(fuel filter, injectors,etc.)....good luck
Old Jul 17, 2005 | 06:00 AM
Pete_SI's Avatar
Default Re: Rough idle and won't Rev! (Ignitecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic &raquo;</TD></TR><TR><TD CLASS="quote">when u rev, does the car sounds like its going to die out.
problem solved!!</TD></TR></TABLE>
Well actualy when we floor it just dies but when we just tap the gas the car will rev until 2500rpm some times 3000rpm and the just seem to die out a bog very bad. But I will try your tip.
Modified by Pete_SI at 11:23 AM 7/17/2005
Old Jul 17, 2005 | 06:42 AM
ToxicBug's Avatar
Checked the MAFS? Maybe it's just unplugged, but might be broken.
Old Jul 17, 2005 | 08:26 AM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Check and see if your getting fuel to all the cylinders, did you do anything with the fuel rail? me and my buddy had a problem when swapping because the injector wires came lose and it was running on 2 cylinders.
Easy way to check and see if the cylinders really work is to unplug spark plug wires one by one to see if one of them isn't getting spark/fuel.
Old Jul 17, 2005 | 08:35 AM
Crasian's Avatar
u are having the exact same problem as me rite now, i have changed the following on mine and it still does it:
-fuel pump
-injectors
-fuel filter
-FPR
-dizzy
-spark plugs
-spark plug wires
-ecu
-map sensor
-O2 sensor
-checked for clogged cat
Old Jul 17, 2005 | 08:53 AM
Pete_SI's Avatar
Default Re: (Crasian)
Thanks guys. What confuses me is that I don't have any CEL. I actualy remove something on the fuel rail. I replaced the thing (sorry I don't know what it is) on the side where it connects to the fuel filter. I just un screwed it and and replaced it, do you have do to anything special to it?
Old Jul 17, 2005 | 09:07 AM
Crasian's Avatar
i dunno what u eman man, did u change the fuel pressure regulator? do u ahev msn too? we can figure this out togeether maybe, add me up, kieran3000@hotmail.com
muahhaha
Aug 27, 2014 06:06 AM
jspek29
10
Oct 20, 2006 06:44 AM
nonv
Dec 3, 2004 08:11 AM
redacura
Jul 18, 2002 11:53 AM
Sirvtec
Feb 10, 2002 03:21 PM
