question about alarm.....
Old Jul 16, 2005 | 04:06 PM
nickolas388's Avatar
Default question about alarm.....
hi everyone, right to the point......
i just got my 97 prelude and it has an alarm. and when you lock the car it would beep indicating its on once i pressed the botton on the remote. it just locks and blinks the lights now. idk what happened all of a sudden. it doesnt beep so im gussing the alarm doesnt activate anymore.
anyone with a similar problem?
Old Jul 16, 2005 | 06:05 PM
The Weather Man's Avatar
Get a Viper 5000 or a Viper 790xv if you want remote start with it. I suggest getting the Viper 5000 because its a 2-way alarm AND(this is the thing i love about it)...you can adjust the shock sensor from the REMOTE!!! HAHA....DEI...the shizznit....sry if it didn't answer your question, but most likely - no one knows.
Old Jul 16, 2005 | 06:51 PM
Odessa's Avatar
Default Re: question about alarm..... (nickolas388)
Maybe the siren is dead?? Can you activate the panic mode and see what it does??
Old Jul 16, 2005 | 08:47 PM
Default Re: question about alarm..... (Odessa)
sorry what is the panic mode idk
Old Jul 16, 2005 | 08:57 PM
Odessa's Avatar
It makes your alarm go off. If your siren still doesn't sound, but your parking lights flash and horn screams, then the siren must be bad or bad connection/wire.
Old Jul 16, 2005 | 09:25 PM
how would i go about doing this?
Old Jul 16, 2005 | 09:29 PM
Odessa's Avatar
Not sure about that. It depends on the alarm you have, but all you really have to know is which button on the remote activates the panic mode. Another thing you could do is lock your car (arm it with the remote) and then try open it with a key. The alarm should go off then.
Old Jul 16, 2005 | 09:31 PM
theres only a button to open/close the door. no panic mode button. but i will try the key thing thanks
Old Jul 17, 2005 | 12:20 PM
i locked the car with the remote then tryed opening it with the key. the only thing that happened was the car opened. no panic mode. anyone know what problem im having?
Old Jul 17, 2005 | 06:27 PM
bump
can anyone help?
Old Jul 17, 2005 | 06:46 PM
maks's Avatar
Default Re: (nickolas388)
Make sure you don't have a blown fuse for starts... maybe even the alarm has an internal fuse, check it out...
I know it may sound silly, but maybe the battery on the remote is dead?
Old Jul 17, 2005 | 08:04 PM
where exactly would i check for the blow fuse. and its not the battery i dont think because it still works for the locking/unlocking
Old Jul 17, 2005 | 10:03 PM
bby6's Avatar
I <3 Rotas
mine does the exact same thing! but the alarm does go off if i press the panic button but if i hit the car or try turning the key or opening the door it doesn't go off. it happened after i installed my strut bars
Old Jul 18, 2005 | 08:45 AM
Default Re: (girLuder)
well its weird....i dont have a panic button, just a lock/unlock button. but when u hit the lock button does it beep indicating the alarms on?
Old Jul 18, 2005 | 09:42 AM
bby6's Avatar
I <3 Rotas
nope, no beep, just the lights flash and locks and unlocks
Old Jul 18, 2005 | 09:46 AM
Wiseguy619's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by girLuder &raquo;</TD></TR><TR><TD CLASS="quote">nope, no beep, just the lights flash and locks and unlocks </TD></TR></TABLE>
Your alarm could be on VALET mode.
Old Jul 18, 2005 | 09:48 AM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by girLuder &raquo;</TD></TR><TR><TD CLASS="quote">mine does the exact same thing! but the alarm does go off if i press the panic button but if i hit the car or try turning the key or opening the door it doesn't go off. it happened after i installed my strut bars </TD></TR></TABLE>
I think that's just because you don't know what you're doing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickolas388 &raquo;</TD></TR><TR><TD CLASS="quote">hi everyone, right to the point......
anyone with a similar problem?</TD></TR></TABLE>
Is this a factory alarm or aftermarket? I had all kinds of problems with the alarm that came with my car (non-factory) until I replaced it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectPenny &raquo;</TD></TR><TR><TD CLASS="quote">Your alarm could be on VALET mode.</TD></TR></TABLE>
Old Jul 18, 2005 | 10:58 AM
snowblind7x's Avatar
Default Re: (ProjectPenny)
I was gonna say the same thing except you said you armed the alarm and opened the door with the key and the alarm didn't go off. Valet mode only effects the beeping when you lock/unlock the car. When you set the alarm and then opened the door with a key were the lights flashing as if your alarm was going off but just no siren? If that's the case, busted siren. If no lights flashing either, busted alarm.
Old Jul 18, 2005 | 02:01 PM
bby6's Avatar
I <3 Rotas
Default Re: (snowblind7x)
phils always so mean to me.
i forgot to add, sometimes i'll drive and my alarm light will be on (now the blue light stays ON when my cars off, doesn't blink like it used to this started when the alarm stopped beeping) and the alarm will go off out of nowhere. scares the **** out of me
Old Jul 18, 2005 | 07:43 PM
the case is. i lock the door with the button, then open is with the key, nothing happens it just opens. no lights, no alarm. this means my alarms busted?
Old Jul 19, 2005 | 06:29 PM
does anyone know my problem?
Old Jul 19, 2005 | 08:18 PM
goae86's Avatar
How about Alpine alarms?
Old Jul 21, 2005 | 01:39 PM
Default Re: question about alarm..... (goae86)
what do you mean.
Old Jul 21, 2005 | 04:52 PM
Odessa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowblind7x &raquo;</TD></TR><TR><TD CLASS="quote">I was gonna say the same thing except you said you armed the alarm and opened the door with the key and the alarm didn't go off. Valet mode only effects the beeping when you lock/unlock the car. When you set the alarm and then opened the door with a key were the lights flashing as if your alarm was going off but just no siren? If that's the case, busted siren. If no lights flashing either, busted alarm.</TD></TR></TABLE>
Wrong. Valet mode disables the alarm and remote start (if you have one) and only lets you open or close your doors.
Old Jul 21, 2005 | 04:55 PM
Odessa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickolas388 &raquo;</TD></TR><TR><TD CLASS="quote">the case is. i lock the door with the button, then open is with the key, nothing happens it just opens. no lights, no alarm. this means my alarms busted?</TD></TR></TABLE>
I don't know if it's busted or not, it could be simply in valet mode. Find out what alarm you have and find a manual on the net for it. Maybe you don't even have a valet mode, who knows??
