JDM H22 Red Valve Cover
Old Jul 16, 2005 | 02:16 PM
crj_lll's Avatar
Default JDM H22 Red Valve Cover
Does anyone know where the most inexpensive Red JDM H22 OEM Valve Cover can be found? Any help would be appreciated.
Old Jul 16, 2005 | 02:22 PM
OEM_ASSASSIN's Avatar
Default Re: JDM H22 Red Valve Cover (crj_lll)
I got mine from jhpusa.com
Old Jul 16, 2005 | 03:47 PM
jg86hawk's Avatar
Default Re: JDM H22 Red Valve Cover (OEM_ASSASSIN)
Ive found some on ebay for about 100... not sure if the sellers are reliable, but take a look.
Old Jul 16, 2005 | 03:50 PM
96H22aLUDE's Avatar
just paint your stock one red if you dont wanna throw down big bux.. youll prob save about 100 bux
edit: i also heard the valve covers on ebay(OBX) leak
Old Jul 16, 2005 | 04:30 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: JDM H22 Red Valve Cover (96H22aLUDE)
yeah you just need to find some red rinkle paint
and i thought the obx or what ever where oems just repainted
Old Jul 16, 2005 | 05:24 PM
96H22aLUDE's Avatar
Default Re: JDM H22 Red Valve Cover (raylude)
yeah the OBX ones are powder coated
Old Jul 16, 2005 | 06:38 PM
eMpAtHy's Avatar
all u need is primer, aircraft remover or something like that and wrinkle paint. viola. u have urself a red valvecover.
Old Jul 16, 2005 | 09:25 PM
crj_lll's Avatar
Default Re: JDM H22 Red Valve Cover (eMpAtHy)
So what color is it actualy? wrinle viola or wrinkle red?
Old Jul 16, 2005 | 10:44 PM
raylude's Avatar
lol wrinkle viola isnt a color, he was just sayin viola all you need is red wrinkle paint primer or adhisive promoter both work well and aircraft paint remover
then you use the paint remover all over it takeing off all the paint then use the primer or adhisive promoter then use the red wrinle paint and the more coats u use the more wrinkle it will have
Old Jul 16, 2005 | 11:09 PM
flashmang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crj_lll &raquo;</TD></TR><TR><TD CLASS="quote">So what color is it actualy? wrinle viola or wrinkle red?</TD></TR></TABLE>
roflmao
Old Jul 16, 2005 | 11:37 PM
crj_lll's Avatar
Default Re: JDM H22 Red Valve Cover (flashmang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flashmang &raquo;</TD></TR><TR><TD CLASS="quote">
roflmao</TD></TR></TABLE>
I see flaming is alive and well. GOD forbid I do not know everything there is to know about a prelude or restoring it. I guess if I did I would not need this forum.
Old Jul 17, 2005 | 02:01 PM
crj_lll's Avatar
Ok, let me make sure I am getting this correctly.
The items I need are:
#1, red wrinkle paint
#2, primer or adhisive promoter
#3, aircraft paint remover
Let me know?
Old Jul 17, 2005 | 03:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crj_lll &raquo;</TD></TR><TR><TD CLASS="quote">Ok, let me make sure I am getting this correctly.
Let me know?
If I were you I would also invest in a new valve cover gasket and spark plug grommets. Some people recommend hondabond to help seal also.
I bought the seals awhile back and if I remember right it was about $16 total from the honda dealership, which BTW is the only place you should get those seals from.
I always thought that the OBX H22A valve covers were F20B replicas. Look at the front of the valve cover.
Old Jul 17, 2005 | 04:32 PM
raylude's Avatar
Let me know?</TD></TR></TABLE>
looks good and yes dont forget the gaskets from honda only its worth the money
and dont forget to fallow the instructions on the cans
heres one im workin on geting the prep work done but dont know what color to paint
i just looked at the pic again lol it still looks painted i guess my cam takes pics too dark
Modified by raylude at 3:51 AM 7/18/2005
Old Jul 17, 2005 | 06:27 PM
does anyone know how much hondabond is?
I heard that you are supposed to put it on the side where the timing belt is.
ONE MORE THING: Get the torque specs on the valve cover studs/nuts. I broke one barely giving it anything. It sucked, had to wait 2 days to get one and they are about $3 each. I think it is 7 ft/lbs but I am not sure.
Old Jul 17, 2005 | 06:52 PM
raylude's Avatar
hondabond cost like 20 bucks
Old Jul 17, 2005 | 08:07 PM
stRodda's Avatar
while your at it, go incognito...
Old Jul 17, 2005 | 08:37 PM
crj_lll's Avatar
OK, I know I sound like a SPED (not an invitation for flamming) but I just want to be sure before I move on. The pic I have attached is the color I am looking for. That is wrinkle red?
Old Jul 19, 2005 | 04:57 AM
iakona's Avatar
vht makes a wrinkle red you don't need an adhesive promoter for. just get some aircraft remover to pull the old paint off, blast clean, tape up anything you want still shiny, and paint. you may need a dremel to get into areas you missed with the tape or tomake them super shiny, but that's it.
Old Jul 19, 2005 | 05:15 AM
DJ_SaNdOz's Avatar
Default Re: (iakona)
VHT makes the wrinkle paint, and so does Duplicolor. I found red & black Duplicolor at my local Autozone, but I could only find the black VHT paint locally. They both do essentially the same thing, and the Duplicolor was only $4.99. if you order it online you end up paying more for shipping than you do for the actualk can of paint....
Old Jul 19, 2005 | 05:57 AM
iakona's Avatar
yep. damn hazardous shipping fees. go to your local body shop or hot rod shop, they usually have the whole vht display. or summit racing sells them for pretty cheap.
Old Jul 19, 2005 | 06:09 AM
00MugenLude's Avatar
IM'd
Old Jul 19, 2005 | 06:23 AM
honda3431's Avatar
I just painted mine on my 4th gen. Took like two days bc I took my time and did a couple extra coats. And it only cost me like five bucks.
Old Jul 20, 2005 | 06:04 PM
raylude's Avatar
now its done this is only 4 coats i just wish the color was more flat
Old Jul 20, 2005 | 07:16 PM
jakeiscool's Avatar
Banned
i have a jdm h22 and my valve cover is black dont spend 200 bucks to be M4D JDM YO
