turbo civic shutting off!
Old Jul 16, 2005 | 01:03 PM
civicdx1's Avatar
Default turbo civic shutting off!
ok i have a 98 civic with 00 b16,and drag turbo kit,p28 uberdata.ok heres the problem yesterday on way to work the car run fine,upon getting a couple of feet from work my car suddenly shuts off.so i parked waited a couple of seconds crank it and it turn on.so 10 hours later when i was going home i turn it on,and it turn on ,but then turn off 5 seconds later.i crank it for about 10 minutes it it wouldn't start so i waited 40 minutes .and it finally started only to shut off on me in the freeway,like if gas was getting shut off.i waited 20 minutes more turn on again let it idle for 10 minutes .it idle fine,so i went home.and it run fine.ok i started doing this a month ago,only once in a while but yesterday it did it 3 times .any idea whats wrong with it? thanks
Old Jul 16, 2005 | 02:58 PM
civicdx1's Avatar
Default Re: turbo civic shutting off! (civicdx1)
helpppppppppppppppppppppp!!
Old Jul 16, 2005 | 06:36 PM
94whtgsr's Avatar
main relay...
Old Jul 17, 2005 | 11:18 AM
civicdx1's Avatar
Default Re: (94whtgsr)
check main relay ,its ok.change rotor ,its was kind of worn out.it work find after.but today it did it again.
Old Jul 17, 2005 | 11:21 AM
Sinner's Avatar
my del sol would shut off when I was low on oil
Old Jul 17, 2005 | 11:27 AM
civicdx1's Avatar
Default Re: (Sinner)
i check oil ,oil is fine.im gonna replace the ignition module and coil ,to see what happens.
Old Jul 17, 2005 | 12:41 PM
civicdx1's Avatar
Default Re: (civicdx1)
just change coil and ignition module in the distributor,still wont start.
Old Jul 17, 2005 | 01:16 PM
b18c1Monster's Avatar
Mines did that too and turns out it was the fuel pump
Old Jul 17, 2005 | 01:31 PM
civicdx1's Avatar
Default Re: (b18c1Monster)
i change the ignition module and coil and it din't start,i tried againg after 15 minutes and it started. i just put in a walbro intank fuel pump a couple of months ago.could it go bad that quick? my fuel pressure is at 40 ,thats the way it was before having problems too.
Modified by civicdx1 at 10:55 PM 7/17/2005
Old Jul 17, 2005 | 05:13 PM
civicdx1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdx1 &raquo;</TD></TR><TR><TD CLASS="quote">i change the ignition module and coil and it din't start,i tried againg after 15 minutes and it started. i just put in a walbro intank fuel pump a couple of months ago.could it go bad that quick? my fuel pressure is at 40 ,thats the way it was before having problems too.
Modified by civicdx1 at 10:55 PM 7/17/2005</TD></TR></TABLE>
Old Jul 17, 2005 | 05:23 PM
JDM-Civic-Hatch's Avatar
dude. put your fuel pressure at 50. 40 is a lil low turboed.
Old Jul 18, 2005 | 12:11 AM
civicdx1's Avatar
Default Re: (JDM-Civic-Hatch)
how would i do that?
Old Jul 18, 2005 | 05:32 AM
notoriousB's Avatar
are you sure the main relay is fine? when mine went it was intermittent, so if I bench tested it it worked, but if it was hot outside it wouldn't work.
when the car's not starting smack the main relay hard and try again. if it starts right up it's the relay...
Old Jul 18, 2005 | 05:44 AM
mugenhatch92's Avatar
my car is doing the same thing
Old Jul 18, 2005 | 05:49 AM
BoostedEG6's Avatar
Default Re: (mugenhatch92)
sounds to me that you have a wire lose somewhere going to your fuel pump. when I put in my fuel cell I had that problem..... but I know you dont have a cell but I would check all your conections to your fuel pump just to be on the safe side
Old Jul 18, 2005 | 07:37 AM
Surftouch's Avatar
My car did this but im running an OBD1 app. But the problem with mine was at the ecu. The the was Ingniton Input wire....Somehow it came undone from the vacf and the car wouldnt start.......You could have a loose wire.....Also check your ECU, I worked on a civic last night.....Would start, but it had fuel and spark....it turned out the ecu fried....check them out
Old Jul 18, 2005 | 07:41 AM
tthame1's Avatar
Default Re: (Surftouch)
Check your obd-II to I conversion harness and check the solders on your ecu. Either of those could cause that problem.
Old Jul 18, 2005 | 11:30 PM
civicdx1's Avatar
Default Re: (tthame1)
well the car worked well today.but it might be the conversion harness since i did buy it used,and it was splice into by previous owner.ill keep u guys posted.
Old Jul 19, 2005 | 01:25 AM
dthrone's Avatar
Coil!
Old Jul 19, 2005 | 05:21 AM
tthame1's Avatar
Default Re: (Spanky Loves Boost)
Are you running stock ignition and coil or is that upgraded? Because if it is upgraded, check the wires going into the distributor and make sure that you have good connections there, that could also be the problem.
Old Jul 19, 2005 | 11:49 PM
civicdx1's Avatar
im running stock ignition,and i just change the coil.it turn off this morning again but it did start after a couple of minutes.
Old Jul 19, 2005 | 11:59 PM
NightRiderS2K's Avatar
In-N-Out Burger
Do you have a fuel pressure gauge?
If you don't, immediately get one.
I had a very very similar problem in the past. Turned out to be my brand new Walbro that pooped out on me somehow.---And I didn't know because I had no way of telling if I had sufficient pressure to keep my engine running.
Same exact symptoms as you.
I spent nearly $400 replacing other parts before finally narrowing it down to my fuel pump.
Old Jul 20, 2005 | 12:15 AM
civicdx1's Avatar
Default Re: (NightRider-gsR)
yeah i do have one and it reads 40.
Old Jul 20, 2005 | 09:45 AM
Surftouch's Avatar
check your harness if somone spliced into it and you got a loose connection that will cause it to do what its doing....mine did the same thing cause my friend spliced into my harness and i had a loose connection....check the Ingition input....thats where my prob is....If it has good connection it would run, but like if i stoped it would not want to start...check out ur harness im sure you will find something!!
Old Jul 20, 2005 | 11:42 AM
well mine shuts off to, but it is because of a cracked piston.....
probably what yours is... do you have your oil line from the valve cover going back into the turbo intake?
or did you get bad gas and it caused denation and blew your motor?
