lug nuts keep loosening????
Old Jul 16, 2005 | 11:50 AM
turbociv's Avatar
Default lug nuts keep loosening????
well, This happened about a month ago and i havent been back to the track since. But after I do my burnout in the burn out box, then run the 1/8 my lugz are loosing on me. If i tighten between each run im ok, but i still doint feel 100% safe.
I have ARP studs with kaiser 3pc aluminum 13X8 raceing wheels. I am using a set of lug nuts from carquest that had the longest thread i could find. Im starting to wonder if maybe the taper is possibly a wrong degree?? however the stock steelies dont have any issues with these lugs loosening whatsoever. Could it be my tires outta balance or maybe a tow/camber issue? I dont have any kinda shakeing in the front end.
Any ideas?? I kinda dont want my wheel flying off at 90mph.
Old Jul 16, 2005 | 03:53 PM
N2O's Avatar
N2O
Default Re: lug nuts keep loosening???? (turbociv)
are your wheels hub centric. try cutting the end off the lug nut to make sure they are seated all the way
Old Jul 16, 2005 | 08:46 PM
turbociv's Avatar
i do not believe that the wheels are hub centric, and the lugz that i use are open ended already.
Old Jul 16, 2005 | 10:05 PM
Redline130's Avatar
Default Re: (turbociv)
Are you torquing them down enough?
Old Jul 16, 2005 | 10:51 PM
turbociv's Avatar
yes, i have too. before i was runnig 20x8x13 on vx wheels and now i run 24.5x8.5x 13 on my new wheels and now the problems start.
Old Jul 17, 2005 | 06:25 AM
Jared's Avatar
if your lugnuts work with your stocks, then they use the same taper seat as stocks. do you have pics of your new wheels? possibly they dont even use a taper seat, and need a flat washer seat like bogarts.
Old Jul 17, 2005 | 02:24 PM
turbociv's Avatar
ill get some pics up, however there is a taper.
Old Jul 17, 2005 | 03:59 PM
SOHCboost's Avatar
2 much power lol
Old Jul 17, 2005 | 05:12 PM
paulzy's Avatar
is the center bore of the wheels sized to fit your hub?
BLK2DOOR
Apr 13, 2010 09:36 PM
Knestis
28
Jun 29, 2005 10:24 PM
Outrun
Feb 9, 2005 05:05 AM
grngsr01
Mar 28, 2003 09:06 AM
VTECTIME
Oct 16, 2002 03:48 PM
