Mom car is throwing a cel... need help with what the code means
P0440
Evaporative Emission Control System Malfunction
P0441
Evaporative Emission Control System Incorrect Purge Flow
P0446
Evaporative Emission Control System Vent Control Circuit Malfunction
its throwing these 3 things... i used a obd reader and deleted the codes, the CEL hasnt come back, but what could those mean? i hear its usually caused when someone fills up their take while the car is running, but it just showed up outa nowhere....
P0441
P0446
Ask the Dealer if TSB 98-081 applies to your car. Do not fill the tank all the way up the neck, they say not to fill the car after the pump clicks off, yes I know it will still take another gallon or so and most of all make sure the original gas cap is on tight, if it is the clicking type when you try to overtighten then make it click at least three times, no after market gas caps on OBD II cars.
Duane in Japan
Duane in Japan
Philbert
Jul 10, 2004 05:44 PM
