finaly i got me a ITR.... now i need help
Old Jul 15, 2005 | 12:47 PM
ITRnorway's Avatar
Default finaly i got me a ITR.... now i need help. UPDATDE WITH PICTURES
well i bought the car yesterday from sweeden. and on the way home today only some miles away from my home after driving many hundred miles, the car suddenly gets a bit lazy and the sound goes deeper. but no CEL
so after i got my car home in the garage the firsth thing i do is check my spark plugs. so i see the that cyl number 2 is totaly black but the other three is fine tan colour..
if a sensor fails would the CEL come on right?
the car is wery slow when reving. idel is @ 500rpm and before was it about 800->
and the car is running on 3 cyl..
Modified by CRXnorway at 7:00 PM 7/24/2005
Old Jul 15, 2005 | 01:09 PM
CW-ITR's Avatar
If there is no sight of oil residue on the plug, it could be as simple as a bad spark plug. Check the gap and the spark emission.
Old Jul 15, 2005 | 01:40 PM
extrah's Avatar
Default Re: finaly i got me a ITR.... now i need help (CRXnorway)
I have no answer for what you`re asking about. Sorry...
Congrats with the purchase. I reckon you are "crx" from the norwegian forum!?
Give us some info about the car. And some pics!
Old Jul 16, 2005 | 09:11 AM
ITRnorway's Avatar
Default Re: finaly i got me a ITR.... now i need help (extrah)
well, after i changed the spark plug and fuel filter and that did not help so i checked the new plugs and i found oli on it!
that would proabobly be a blown valve seal?
yeah http://www.club-honda.org was down yesterday...and im ^crx^ there and i still have the old car
well the car is #1240 and in CW of course thats the finest colour.
it is equped with:
* mugen CF hood
* after market styling kit (well i was looking for a OEM ITR but the kit is pretty fine so i guess im keeping it on)
* CF rear wing, he told me mugen but i doubt it
* DC sports header
* HKS cat back
* EBC tubo groove disc and green stuff pads
* SS brake lines
* DC short shifter
* Auto meter gauges
* mugen valve cover
* Tenso r CAI
* koni adjusteble dampers (dont remember the spring manufactor)
* misc interior touch up`s
* APR smal F1 carbon mirrors
well and a big shitty stereo and i almost forgot the altezza lights! but i got the OEM in my garage so they sould be mounted soon
well the pictures come up later..
Old Jul 16, 2005 | 10:14 AM
nholmes's Avatar
Before you bought the car did you have the car inspected? Do you have a compression and leakdown test done?
Old Jul 16, 2005 | 11:45 AM
eMpAtHy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXnorway &raquo;</TD></TR><TR><TD CLASS="quote">well, after i changed the spark plug and fuel filter and that did not help so i checked the new plugs and i found oli on it!
it is equped with:
* mugen CF hood
* DC sports header
* HKS cat back
* SS brake lines
* DC short shifter
* Auto meter gauges
* mugen valve cover
* Tenso r CAI
well the pictures come up later..</TD></TR></TABLE>
those are all worthless mods besides the koni's if they the koni yellows. it could also possibly be piston rings.
Old Jul 16, 2005 | 12:50 PM
ZygSpeed's Avatar
Check the rotor/cap and plug wires next ...Good luck.
Old Jul 16, 2005 | 02:23 PM
ITRnorway's Avatar
yeah it was on a buyes check. the comp was wery good but did not see a leak check. and i have inspected the dizzy and it looks good.
well it is some usless mods but i could easely keep some of them
Old Jul 17, 2005 | 11:25 PM
ITRnorway's Avatar
Default Re: (CRXnorway)
BUMP!
if i must replace the valve seals. is it any more i should do with the top?
the honda shop told me it could be the oil ring on the piston
Modified by CRXnorway at 10:33 AM 7/18/2005
Old Jul 18, 2005 | 04:50 AM
CW-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXnorway &raquo;</TD></TR><TR><TD CLASS="quote">BUMP!
Modified by CRXnorway at 10:33 AM 7/18/2005</TD></TR></TABLE>
Well, if it puff smoke between hard shifting, it may be the valve seal. Otherwise, bet on the oil ring.
Old Jul 18, 2005 | 09:08 PM
ITRnorway's Avatar
Default Re: (CW-ITR)
okay. so the engine will not take any more damge if im driving it?
if not could i try do that... or i the best thing is to get an honda mechanic to check it up for me as soon as possible...
Old Jul 19, 2005 | 05:38 AM
type_r_jon's Avatar
I wouldn't drive it. Do a compression test and if the bad cylinder is 0 or close to it, see if adding oil in the bad cylinder gets it up to 75 psi or so. If it does could be valve(s), if it does not could be ring(s). Do you hear any piston slap? You may be causing damage to the cylinder walls if you do. Do you have an engine light on? Do you know what code it is spitting out?
TAKE IT TO A MECHANIC NOW
Old Jul 19, 2005 | 09:06 PM
ITRnorway's Avatar
Default Re: (type_r_jon)
it dont have any enigne lamp/warning on so it dont throw me any codes.
i have a session at the honda dealer at friday.
Old Jul 22, 2005 | 03:36 AM
ITRnorway's Avatar
well it was no oil recedue on the spark plug. but unburned fuel since the exhaust vales was burned stuck @ open.
and the shop in norway was demanding a extreme amount of money, that you dont belive me!
but he talked about that the valve seat could be so damaged that the top would just be trash.
who is the best valvetrain upgrade on a b16c6? what i have understand is it just wrong to upgrade the cam on stock pistons?
Modified by CRXnorway at 12:46 PM 7/22/2005
Old Jul 24, 2005 | 09:59 AM
ITRnorway's Avatar
http://forum.club-honda.org/at...=8495
http://forum.club-honda.org/at...=8493
http://forum.club-honda.org/at...=8496
http://forum.club-honda.org/at...=8494
http://forum.club-honda.org/at...=8492
here is pictures of my cylinder head. is this just FUBAR or is it any hope for a poor kid like me?
how can i check if my valve seat is toasted and not usable anymore? and if is is worn out could i replace it or is the cylinder head on pice of cast alu?
and there is a picture of my rocker arms. you can see some wear damage but i can not feel it with my finger tip. so i guess that is nothing to worry about? right?
the same thing is about the top of one cylinder sleeve
Old Jul 25, 2005 | 06:30 AM
ITRnorway's Avatar
BUMP
Old Jul 26, 2005 | 03:50 AM
ITRnorway's Avatar
BUMP
brent parham
Jan 21, 2013 03:30 PM
turbo-crx
Oct 18, 2007 04:35 PM
jc2801
Mar 28, 2007 06:49 PM
B16CivicEX
Jun 3, 2006 07:02 PM
