Turbo Kit for 05 RSX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baxter04 »</TD></TR><TR><TD CLASS="quote">What's the best Turbo Kit for 05 RSX based on your experience?</TD></TR></TABLE>It's way too early to tell. I can probably count on both hands the turbo 05 rsx's on my hands. I personally would stay away from Greddy just because I've known 3 people personally that had their's burn their car up.
I'd go with cybernation stage 1 or 2 if I were you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaziniflo »</TD></TR><TR><TD CLASS="quote">It's way too early to tell. I can probably count on both hands the turbo 05 rsx's on my hands. I personally would stay away from Greddy just because I've known 3 people personally that had their's burn their car up.
I'd go with cybernation stage 1 or 2 if I were you.</TD></TR></TABLE> just replace the greddy oil lines with something better
i have been running a greddy on mine now for weeks and its fine....you just need to know how to install them right andnot burn them up, or not runtoo much boost and blow ur engine, you needto be smart and not try to show off you car.....everything fits perfectly, but there is some wiring differences in the ecu....my friends and i installed mine and it is fine... go with bigger injectors and a fuel rail, cause with a high compression car you will lean out. im running 10 psi now and its at 289whp, leaned out my 440cc injectors, i got 750cc nows but im am also build my block for a 9:1 compression and will be ruinning higher boost...
bottom line dont be stupid with the boost...and make sure all fuel lines and oil lines are tight and there are no leaks...thats how car blow up!!!!
I will never buy a complete "turbo Kit". If i were you i would peice together my own turbo kit, you will end up with better parts and it might even come cheaper depending of how good of a shopper you are.
if you want to just go turbo i'd go for a complete turbo kit...me i wanted to prove greddy wrong cause they told me i couldnt turbo an 05.....but if your going big like im about to, u want to piece a kit of ur own together....
Since he's looking for a Turbo setup for a 05 RSX-S i agree that it'll prolly cost more to piece a kit together. You might be looking at having an exhaust manifold custom made unless you could find one on ebay but then you'd prolly be limited to selection.
Before i opted for the greddy kit on my EP3 i looked around and found that it was going to be a little less time to just buy the kit than to piece one together and still possibly get the same quality outcome. If you did piece one together there is the greater possiblity that problems could arise due to the mis-matching of parts and what not. I would've been happy with the Greddy kit if i would've had it professionally installed but since the guy said he knew what he was doing and really was "winging" it from past experience, it's caused my motor to take a crap twice... I'm a full believer that it WAS NOT the kit but in installation error... twice.....
redliner8000
Jun 4, 2005 02:00 PM
Wattup Though 00
May 4, 2004 10:52 AM
