b16 in 91 std runs fine but trouble starting in the morning
Alright so i have a obd0 b16 in my 91 std. In the mornings when i go to start it, it will crank over for like 6 seconds and then ill stop and the car will stutter a little.
It kinda sounds like its not getting any gas. All of a sudden it comes to life and idles at about 2000 rpms. After a couple minutes the idle will go back down to a normal 900 rpms.
What should i check first i was think maybe the fuel filter was clogged or does it have to do with my spark?
Thanks
Thanks
Well you should check your basic things first like fuel filter, cap and rotor. When was its last tune up? it might be in need of one. And check your fuel pump.
Graiskye
Oct 1, 2017 09:07 AM
WWTeg
Mar 9, 2008 05:00 PM
