TYPE-R CRANK STROKED TO 96MM F.S. SO CAL.....
I HAVE A ITR CRANK THATS BEEN STROKED TO 96MM BY CASTILLOS CRANK'S NEVER BEEN USED NO NEED FOR IT WAS GOING TO USE TO BUILD MY B SERIES MOTOR BUT HAVE MY OTHER CAR TO BUILD.... PM IF INTERESTED LOCATED IN SO CAL... SELLING FOR $950.00 SHIPPED OR $900.00 PICKED UP pics are on second page
Modified by NA-DB8 at 10:42 AM 7/15/2005
Modified by NA-DB8 at 4:46 PM 7/18/2005
Modified by NA-DB8 at 11:43 AM 7/27/2005
I'LL TRY TO TAKE PICS THIS WEEK. BUT YEAH YOU CAN STROKE THE CRANK. THE TYPE R CRANK IS @ 87MM STOCK. MINE HAS BEEN STROKED TO A 96MM...
Modified by NA-DB8 at 10:07 AM 7/20/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-speed Ricer »</TD></TR><TR><TD CLASS="quote">Post pics. Never knew you could restroke a Crank...</TD></TR></TABLE>
correct and have asked some weird questions but never knew this was possible???
WELL DEPENDING ON WHAT KIND OF PISTON YOU ARE GOING TO USE. IF USING STANDARD OR OEM YOU CAN USE STOCK RODS BUT AFTERMARKET PISTONS DEPENDING ON THE WRIST PIN LOCATION YOU MIGHT HAVE TO USE CUSTOM RODS...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t-blizzard »</TD></TR><TR><TD CLASS="quote">sick! so im assuming this was going in a deckplated setup?</TD></TR></TABLE>
Stroke like that would have to be. Still waiting for pix. Sounds like a bad *** crank.
will take pics tonight... but i need some one to host the pics as i dont know how too post on h-t. as for the set up it can go with a deck plate or without. I was going with my crank, .40 over itr pistons, and custom rods.. oh and rehoned my block
i have no use for the crank as i am building my h22 eg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA-DB8 »</TD></TR><TR><TD CLASS="quote">I'LL TRY TO TAKE PICS THIS WEEK. BUT YEAH YOU CAN STROKE THE CRANK. THE TYPE R CRANK IS @ 87MM STOCK. MINE HAS BEEN STROKED TO A 96MM...
Modified by NA-DB8 at 10:07 AM 7/20/2005</TD></TR></TABLE>
did you have it off set grind....
