i bought a 93 hatchback shell
ok so i bought a 93 hatchback shell and it has abosoulety nothing..no harnesses..nothing.. im building it from scratch..all it has is the steering wheel.. ignition and hand brake..
now im trying to start my project.. to be hoenst i just want to make it back to stock and make it a daily driver
just had some questions.. should i put a stock dash with its harness.. or put in the gsr dash with the gsr harness since there is nothing there
what about motor.. d15b7 with stock harness...
and also : for the carpet.. which carpet can i get to fit the hatchback ??
First off. I have pretty much every part you need. So pm me if you're interested.
Second, integra dash looks cooler, go here for specifics: https://honda-tech.com/zerothread?id=1211255
Third, for daily driving, d15b7 is decent but I'd opt for a d16z6 because it's a direct bolt in and you'll have 23 more hp.
Fourth, a stock carpet can be found here on ht for very cheap. Or you can get a replacement off ebay but you'll have to cut the pattern out which is entirely lame. I recommend the former.
Im not tryin to hijack the thread but does anyone know the weight differences between the teg dash and the civic one? Not that you would be concerned about this at all b/c it is just a DD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by labatia »</TD></TR><TR><TD CLASS="quote">i dont know if i really want to spend any money on this car
im 21 and when im 24 i plan on buying a luxury car
so is it really worth it?</TD></TR></TABLE>
LMAO, dude you need to figure out what you want before you start spending your hard earned money.
I'd guess that you'd end up spending more on reassembling this car then just buying a bone stock one for cheap. It also sounds like you don't know what you're doing so you'd probably end up spending more after people take advantage.
If I were you, I'd sell it now and buy a car that's in your budget, safe, reliable and bone stock.
Best of luck
Best of luck
If you're looking for a project, the Integra dash would set the car out from the rest and make it that much better.
It will take more time and work though.
If you want to get that thing up and running, I say just get the Civic dash and corresponding dash harness.
Throw in a EX/SI cluster or JDM one and you're set.
that has nothing to do with me not knowing what im doing with this car
i know what im doing but im asking for peoples ideas
i didnt know that was such a bad thing to do
I'll point out one thing based on experience (being in Canada as well) don't buy your parts from the states because Canada customs will charge you an arm and a leg on everything that comes over, not to mention ridiculous shipping costs of larger items such as the dash.
In southern Ontario there are more than 100 large and well known junkyards which mostly or even all have at least one EG hatch. The 4 that are local to me here all have them... My advice is to find one, pull the whole interior from it part by part, or just get the whole car for cheap. Get a price on the entire interior before starting, they'll give you a cheaper price than if you pay part by part.
I started out with a hatch shell just like that about a year ago and it is quite a project. Be prepared to spend a lot of money if you want full stock interior. I did that and spent over $1000 on stock interior. Just pick up some Integra GSR Seats and some door panels and a dash. You will not spend a whole lot of money that way, and it will be comfortable for a daily driver. Good luck with the project. Post some before and after pics.
spork motorsports
Oct 26, 2006 02:51 PM
