Integra and Civic PARTS!!! Cheap!!! MUST GO ASAP!! PICS!!
Im cleaning out my garage. Need to make room for parking space.
**PLEASE BUMP AFTER VIEWING**
92-95 Civic Parts:
Driverside Airbag. Black. Airbag only. $40
Stock Passenger side Tail lights. Both pieces. $10
Stock EX side mirrors. Power. Needs paint. $30
JDM Sir Intake air box. Same as USDM just have japanese writing on carb sticker. Comes with filter. No Intake arm $25
EX Gauge Cluster. Missing Fuel/Temp Gauge. $30
'95 Sohc Vtec Del Sol Shift linkage w/ generic short shifter. $30
96-00 Civic Parts:
OBD2 P2N ECU. I belive its off of an HX. $20
OBD2 P2E ECU. DX ecu?? not sure. $20
D16Y7 Starter (Manual Tranny). Should also work with any D16's w/manual tranny. $35
A/C Compressor w/bracket. Off of 97 EX. $40
Power Steering pump w/bracket Off os 97 EX. $40
D16y7 Rear T-Bracket $15
D series tranny bracket for M/T. $5
D16Y8 EX Distributor. Plug is cut. $30
DX Purge canister. $15
AEM Tru Time Cam Gear. Off of d16y7 (DX). $35
94+ Integra Parts:
Semi-rebuilt '96 LS P75 Head. Completely disassembled. Hot tanked, refreshed valve seats, resurfaced deck. Comes complete with reseated vlaves, stock springs, retainers,cams w/gears, int. manifold, and all necessary hardware to put it together. No Distributor, throttle body or valve cover. *Missing one exhaust valve. You will need to get new valve seals from the dealer as the old seals were damaged during hot tank cleaning. $100
95 LS B18B1 Block. Comes only with original crank and mains. Walls are also clean. No cracks or scoaring. LEGIT!! $120
OEM GSR top end gasket rings: valve cover O-rings (gasket around sparkplug area), P72 valve seals, Valve cover nut washers, Cam caps, exhaust manifold O-rings. All pcs are brand new in bag. $40
OEM Crank/oil pump seals. Brand New. $10
Tsudo axle back exhaust for 94+ 4dr Intgera. 5 Zigen fireball style w/slanted stance. Comes w/silencer. Great condition w/some minor scratches. $85
JUN Style 4-1 1pc headers. For '95 GSR (NO O2 Bung). Stainless finish. No dents or cracks. 2" collector. Should also work with other year and model Integras w/some modifications. SOLD
Generic front-upper tower strut bar. SOLD
OEM GSR front-upper tower strut bar. $20
95 LS fuel pump. $15
GSR spark plug cover. SOLD TO Taiwanze7
OEM LS Muffler tip. $10
Stock LS B-Pipe. $30
95 LS Throttle body. Comes with Map sensor. TPS is broken. $35
97 LS Power steering bracket. $15
95 LS A/C Bracket and mount. $30
95 LS driver side bake caliper. SOLD to Taiwanze7
95 LS Front Passenger side hib assembly. Comes with upper A arm, blake caliper, and axle shaft. $45
Miscellaneous parts:
Plasmaglow 4pcs Undercarriage Neon Rod Lights. Color is blue. 1 rod is blown. The remaining 3 works fine. $45
OEM Honda Tape Decks: $35 each.
Items are priced to sell. Located in San Leandro/Oakland Area. PICK-UP ONLY! *I will not deliver or meet halfway.
Will ship at buyer's expense.
EMAIL IS KEY: B5eries@yahoo.com
Modified by B_Series_4_Life at 7:45 AM 7/16/2005
Modified by B_Series_4_Life at 7:38 PM 7/16/2005
Modified by B_Series_4_Life at 2:43 AM 7/17/2005
92-95 Civic Parts:
96-00 Civic Parts:
94+ Integra Parts:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9 3 d e l s o l »</TD></TR><TR><TD CLASS="quote">still got that gsr strut bar?</TD></TR></TABLE>
Yes I still have it.
EGh22please
Oct 7, 2010 09:34 AM
