FS: Motor mounts, ac, ps, alternator, shiftlinkage, axles, and ABS sensors/modulator
[B]<FONT SIZE="10">All parts are off a OBD I GSR unless otherwise noted.</FONT>
AC Compressor - $50 shipped
Second AC Compressor - $40 shipped
Alternator - $45 shipped
Alternator brackets - $15 shipped
Starter - $50 shipped
Axles - $150 shipped (half shaft not included)
AC bracket - $30+sh
Drivers side upper mount - $25+sh
Second drivers upper - $25+sh
Rear mount - $25+sh
Rear mount (center section is ripped out, TORN) - $5+SH
Upper tranny mount - $25 shipped
Tranny lower mount - $25 shipped
Torn tranny lower mount - $5+sh (TORN)
PS pump - $30 shipped
GSR PS cooler (gsr/itr only) - $15+sh
PS Reservoir - $10+sh
Civic EX Power steering pump w/ AEM underdrive pulley - $60 shipped
LS Alternator w/ AEM underdrive pulley - $80 shipped
IACV - $25 shipped
Vtec solenoid (connector is broken, but still plugs in fine and works perfect) - $45 shipped
Integra ABS Modulator - $60 shipped
Integra ABS ECU - $25 shipped
ABS Wheel sensors - $20 shipped each (all available currently)
Tranny bracket - SOLD
http://www.bseriesparts.com/im...t.jpg
Modified by 95 integra at 11:27 PM 8/30/2005
AC bracket - $30+sh
Rear mount - $25+sh
IACV - $25 shipped
On that Water Pipe or Thermo Tube : The last, or third outlet tube, is that bent or cut in any way or is that just the flash??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 »</TD></TR><TR><TD CLASS="quote">On that Water Pipe or Thermo Tube : The last, or third outlet tube, is that bent or cut in any way or is that just the flash??</TD></TR></TABLE>
flash...I think I have 3 of them, so I can assure you one of them is in good condition.
Updated post, sold linkage, alternator, starter, a few mounts, 1 ps pump, thermo housing, thermo tube, exhaust mounts, half shaft and some misc other stuff.
