TPC sensors
How do you remove the sensors that look like they are riveted to the throttle body on my b16a it just unscrews and are the all the same on the b series and d series any info. would help. Thanks
you have to cut small slots in the rivits then unscrew them with a flathead screw driver.
all TPS are the same between B and D, just make sure to calibrate it after you install it.
