Brake Rotors
Old Jul 14, 2005 | 07:57 PM
jayfowens's Avatar
Default Brake Rotors
Okay, I'm just learning stuff about my car and I'm too lazy to take off the rear wheel to see so, Is my 1995 Honda Accord EX 4-clyinder equiped with 4 disc brake rotos or 2 in the front and 2 drums in the back?
Old Jul 14, 2005 | 10:09 PM
hondatuningboi96's Avatar
Default Re: Brake Rotors (jayfowens)
i would think u would have rotors all the way around dude all the ex's come with 4 disk brake rotors
Old Jul 14, 2005 | 10:36 PM
jayfowens's Avatar
Default Re: Brake Rotors (hondatuningboi96)
thanks thats all I wanted to know, I'm ordering Brembo cross/drilled rotors and I needed to know
Old Jul 14, 2005 | 11:05 PM
Nick H's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayfowens &raquo;</TD></TR><TR><TD CLASS="quote">thanks thats all I wanted to know, I'm ordering Brembo cross/drilled rotors and I needed to know</TD></TR></TABLE>
actually you are ordering brembo blanks that have been machined by (probably some shitty) shop to be cross drilled...most end up cracking on you, which can do damage to your calliper...there's also absolutely no point in having drilled, slotted or cross drilled rotors for street driving...the whole idea behind this racing technique is to dissipate heat under numerous heavy braking situations...
i would also hope that you are not blind enough to not be able to see the rotors behind the 5th gen EX wheels...
Old Jul 15, 2005 | 02:49 AM
The_Todd's Avatar
Farts in the shower
On the 6th gen accords rear brakes were on option I believe.
Don't get crossed drilled rotors unless the manufacture sells them like that. If you upgrade your pads, calipers, fluid and lines your braking power will be substantially better than oem.
Old Jul 15, 2005 | 12:17 PM
goowakjai
Guest
Posts: n/a
Default Re: Brake Rotors (Nick H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">actually you are ordering brembo blanks that have been machined by (probably some shitty) shop to be cross drilled...most end up cracking on you, which can do damage to your calliper...there's also absolutely no point in having drilled, slotted or cross drilled rotors for street driving...the whole idea behind this racing technique is to dissipate heat under numerous heavy braking situations...
i would also hope that you are not blind enough to not be able to see the rotors behind the 5th gen EX wheels... </TD></TR></TABLE>
wut makes u so sure there blanks? does brembo not make cross-drilled rotors for our aplication?
Old Jul 15, 2005 | 03:26 PM
C_H_A_D's Avatar
Default Re: Brake Rotors (.ken)
5'th gen EX is standard 4 wheel disk and the LX is front disk/rear drum. So you should have 4 wheel disk I found this out at cars.com BOOKMARK IT
Old Jul 15, 2005 | 03:40 PM
jb.'s Avatar
jb.
yes its not that hard, use a little commen sense next time
Old Jul 15, 2005 | 04:30 PM
The_Todd's Avatar
Farts in the shower
Default Re: Brake Rotors (StockAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockAccord &raquo;</TD></TR><TR><TD CLASS="quote">5'th gen EX is standard 4 wheel disk and the LX is front disk/rear drum. So you should have 4 wheel disk I found this out at cars.com BOOKMARK IT</TD></TR></TABLE>
Oh, I didn't know directly off hand.
DelsolioGSR1996
Sep 4, 2006 05:14 PM
jorge99hx
25
Dec 10, 2005 12:52 PM
hans stoner
May 9, 2004 05:58 PM
wutangben
Feb 12, 2003 09:15 AM
