for those with Hasport mounts
Old Jul 14, 2005 | 04:20 PM
CaptivaBlue's Avatar
Default for those with Hasport mounts
I just swapped a B16 into my Sol and when I shift there is a modest "thunk". It is not real bad, just noticeable, it was worse when until I realized the real bracket was missing a bolt, I had the dealer inspect and secure all bolts in the rear bracket and mount, the side mounts are secure as well. He drove it and didn't report anything unusual, seems okay to me, just want to be sure.
I apologize for the shitty grammar.
Old Jul 14, 2005 | 04:31 PM
Jeremy D. Swain's Avatar
Default Re: for those with Hasport mounts (CaptivaBlue)
So, what are you exactly asking? Or were you just letting us know your bolt came loose?
Old Jul 14, 2005 | 04:42 PM
SOHC4life 96's Avatar
Default Re: for those with Hasport mounts (O-Snap!)
Yea. If you are asking if everything is fine, then yes. Other than the fact that you spent to much money to have some bolts tighten down, yes everything is and will be fine.
Old Jul 14, 2005 | 09:52 PM
Default Re: for those with Hasport mounts (SOHC4life 96)
For clarification, what I was asking is if the jolt after shifting is normal. All the bolts are in place.
Old Jul 14, 2005 | 10:51 PM
JDMlyfestyle's Avatar
what mounts do u have. Hasport mounts are usually pretty stiff so you will feel alot more in the cabin
Old Jul 14, 2005 | 11:39 PM
Hatch It's Avatar
Default Re: (JDMlyfestyle)
Does the entire car jolt? if so its normal...
all hasport mounts are made stiffer than those that are stock.
When you use these mounts it makes the whole motor stiffer with the chassis which may cause it to jolt when you shift....
I think its normal...unless the motor jolts and not the car (if you can just ehar the motor banging around)....
good luck, i never heard anything bad about Hasport so you should be aright
Old Jul 15, 2005 | 12:37 AM
RangerDan's Avatar
Default Re: (Hatch It)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch It &raquo;</TD></TR><TR><TD CLASS="quote">Does the entire car jolt? if so its normal...
good luck, i never heard anything bad about Hasport so you should be aright </TD></TR></TABLE>
This makes sense.
oh, and calling Hasport and asking them makes sense also.
Hyoriu
Nov 28, 2008 09:32 PM
vlc92189
May 7, 2008 06:28 PM
r1de4life
May 27, 2007 09:32 AM
ICeDoUt
14
Sep 27, 2005 01:14 PM
dub204
Jun 8, 2004 10:17 AM
