yamaha R6 undertail / fender eliminator ?s
Old Jul 14, 2005 | 04:16 PM
redline201's Avatar
Default yamaha R6 undertail / fender eliminator ?s
ok whats the difference between a fender eliminator and the undertail
is one more legal than the other ?
is it illegal to have your signals intergrated to your tail lights?
i need some ideas on how to get ride of that ugly rear fender
thanks
Old Jul 16, 2005 | 11:29 PM
Duster's Avatar
Default Re: yamaha R6 undertail / fender eliminator ?s (redline201)
Fender eliminator is simply that, it removes the stock un-godly fender and replaces it with a nice small peice of steel that sits where the old one used to be, and for only $200!!! woo hoo....
Undertail kit is MUCH more expensive and it intigrates your turn signals into the tail and it also eliminated the gap between the tire and tire well...
Where i live it is not illegal to have your signal lights itegrated in your tail lights, but that could vary from place to place...
You could always just remove the stock fender, buy yourself some flush mount or short stalk signals and install those and just bend you licence plate to bolt into the tire well....thats cheap and looks good if done properly
Old Jul 17, 2005 | 09:02 AM
redline201's Avatar
Default Re: yamaha R6 undertail / fender eliminator ?s (04Gixxer7K)
cool thanks
what are some good brands to look for ?
Old Jul 17, 2005 | 11:37 AM
Duster's Avatar
For undetail kits i have no idea to be honest with you, ive never looked into them, they look great but too much money...
Fender eliminator kits can be bought all over the place, Id say you best bet is to buy one from a guy who can make them himself because it will cost about about $40 instead of $120-$200.....If you know someone who works in metal fabrication nows your time to take advantage, they are VERY VERY easy to make...Or you can get em on ebay cheap....but i beleive if you want brand name, lockheed & phillips makes one...
As for flush mount signals and short stalk, there is alot of brands on ebay you can checkout, and also lockheed and phillips makes those as well, there is also some upper end flush mounts that match your paint and fit perfectly for your bike if you grab a motorcycle magazine there is all kinds of advertisments for those too...
Id highly recommend installing your fender elim kit and your signals yourself, as taking it to the dealer they will charge you probably $40 to install and it won't take you long as long as you hook the wires up the same as you disconnect them... However if you do decide to go with an undertail kit you might want to get them to install it as the fiberglass peices they will install are very precise to fit the bike...
Old Jul 17, 2005 | 09:20 PM
chitownrida's Avatar
hotbodies undertail
Old Jul 23, 2005 | 12:35 PM
redline201's Avatar
Default Re: (chitownrida)
where do you mount the lisence plate with the hotbodies
Old Jul 23, 2005 | 09:40 PM
comes with bracket.. i think you mount it anywhere you want on the actual piece (drill holes)
Old Jul 24, 2005 | 12:46 AM
ngng's Avatar
go to home depot and pick up two l brackets
Pinner13
Paint and Body
Apr 29, 2011 04:08 PM
[ej]Jonathan
Other Make Vehicles
Jun 25, 2010 11:34 AM
Hammtheman
Mar 31, 2009 03:53 PM
honda94accord
Apr 22, 2007 01:10 PM
1bar
Honda Motorcycles
Oct 6, 2005 06:29 AM
