Big enough welder?
I am doing my auto d16y8 to manual b16b swap currently. we just drilled out all the spot welds on the pass. tranny mount, and we are now ready to move it forward and re weld it. I have only a 100 amp welder. Does anyone know if that will be enough? Any suggestions. thanks alot
Sean
Sean
I wouldn't use an arc welder for something of that sort.
Personnaly I would use an oxyacetylene, mig or a tig welder if you can get ahold of one.
If you do use the arc welder I hope you are good with it because it will be a bit tricky.
u_tal
Jun 14, 2004 02:09 PM
b16dragger
Mar 29, 2004 12:36 PM
