fog light powersorce
i just recently purchase fog lights and i wired them with out a relay and just a 30 fuse. i got my power from the parkinglight powersource from the fuse box in the cabin. is this source reliable enough to hold the power to the fog lights without messing somthing up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goshred025 »</TD></TR><TR><TD CLASS="quote">thanks ill redo it tomorrow.</TD></TR></TABLE> You can use the park light freepin for power, [through a switch] to trigger the relay, that way even if you forget they are on, when you turn off the lights they are off also, and the light warning chime will remind you that the lights are on.
94
94
