What ECU + power loss
I have a 97 civic ex with a 00 B16a2 swap. I'm running a gsr ecu and have been running it for about 2 some yrs. I just found out that it's not the right ecu to be using and was told I'm losing power. I'm looking to find out what ecu to use and about how much power I'm losing
Thanks
Alex
.Thanks
Alex
A gsr ecu activates vtec at 4800 rpms which is too early of an engagement for a almost stock b16 motor. This would cause you to engage vtec & loose power until around 5300 rpms.
Check out: https://honda-tech.com/zerothread?id=1242980
