b16 swap materials?
Old Jul 14, 2005 | 09:54 AM
90civSi's Avatar
Default b16 swap materials?
i have a 90 civic Si. i am planning on doing a b16A swap and have searched but cant find to make sure i am getting everything i need. i am planning on gettin the complete swap from hmotors and am gonna get the LSD transmission. here is a list of what the swap comes with...
- Motor
- Cable Tranny (Y1, S1, J1)
- ECU (PR3, PW0)
- Axles with Half Shaft
- Shift Linkage*
- Stock Motor Mounts*
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
Is there anything else that i will need for the swap???
help would be apreciated
Old Jul 14, 2005 | 10:30 AM
Bjorn20's Avatar
Default Re: b16 swap materials? (90civSi)
u need different shift linkage, axles and i think engine mounts
Old Jul 14, 2005 | 10:35 AM
EP3_05's Avatar
Motor Mounts(Aftermarket)
Shift Linkage(Aftermarket or cut, shorten, and reweld an integra linkage)
New axles because the ones with the swap will probably be toast
Radiator Hoses(Upper-92-93 Integra GSR Lower-90-91 Integra LS)
You will need to add extra wires for VTEC, 2nd O2 sensor, knock sensor
Optional parts:
Clutch
Thermostat
Timing belt
Water Pump
New plugs and plug wires
Dist. Cap and rotor
front and rear main oil seals
head gasket
oil pan gasket
valve cover gasket
crx4ever
Jun 12, 2006 09:45 PM
LS REX
Jul 23, 2004 07:21 PM
Mr.c
Nov 7, 2003 03:21 PM
