HELP! Clifford Alarm with Built-In Door Lock Relay
Guys I need some help: This is for a 1989 CRX Si
I have a Clifford Matrix 10 with built-in relay for door locks. There are 6 wires that's coming out of the haress and I can't see to get it to lock or unlock. This is for a 2 wires actuator. Can someone let me know what I'm doing wrong. I totally appreciate any help. Even better if you come by to just hook up the wire, everything is done except wiring to the alarm itself, I'll buy dinner. I'm located in San Francisco.
Thanks in advance.
Here is the Relay Harness Wiring Diagram:
Black/White DomeLight Supervision Relay Input #87
White/Black Lock #87a Normally Closed
Green/Black Lock #30 Common (Output)
Brown/Black Unlock #87a Normally Closed
Blue/Black Unlock #30 Common (Output)
Violet 12 volt
Modified by Lex2Go at 6:37 PM 7/14/2005
Modified by Lex2Go at 6:38 PM 7/14/2005
Thanks in advance.
Violet 12 volt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lex2Go »</TD></TR><TR><TD CLASS="quote">Guys I need some help: This is for a 1989 CRX Si
Thanks in advance.
Violet 12 volt
Modified by Lex2Go at 6:38 PM 7/14/2005</TD></TR></TABLE>
Green/black and blue/black are your outputs to the actuators.
you need to ground the white/black and brown/black wires.
violet still needs to be wires to +12v.
JT
Thanks in advance.
Violet 12 volt
JT
Thanks JT for the quick reply. I've wired it exactly the way you described and nothing. I'm bring it to a shop latter today if I can't figure it out. I thought it was going to be a straight forward and quick install but this is giving lots of trouble.
Hmmm, that should be it. Have you checked if any power is coming out from the blue/black and green/black? You can just put a test light to the 2 wires. Or at least check that you have 12v coming out of either one. Are your actuators new? You can shoot power to them also to make sure they work.
JT,
You are absolutely right. I try it again after work, but this time I taped the ground wires into a different location, and it work perfectly. Thank you so much for your help.
Lex
Lex
watacivic
Audio / Security / Video
17
Apr 17, 2007 12:53 PM
