Need help on v-tec on h22 in a hatch
Old Jul 14, 2005 | 08:11 AM
allmotor_guys's Avatar
Default Need help on v-tec on h22 in a hatch
I have a 1993 hatch with a jdm h22 my v-tec kick on only when my car starting to warm up. If I drive it for five to ten minnute then my v-tec dont want to kick on anymore. My oil level is where it suppose to be and my motor is running perfectly fine. Any info let me know thanks........
Old Jul 14, 2005 | 08:31 AM
six_speed's Avatar
vtec only engages at normal operating temperature and normal oil pressure.
Old Jul 14, 2005 | 08:50 AM
The Phil's Avatar
Default Re: Need help on v-tec on h22 in a hatch (allmotor_guys)
Look in the prelude forum for the troubleshooting VTEC thread.
Old Jul 14, 2005 | 08:52 AM
B18CR_EJ2's Avatar
Default Re: (six_speed)
like he said vtec will only engage once the car is at normal operating temp and pressure so im gonna guess that maybe your thermostat isnt working properly or something isnt letting the temp or pressure stay at the right level because generally your motor shouldnt engage vtec until it has ran for about 5 minutes and warmed up to regular operatin temps?????
Old Jul 16, 2005 | 01:48 PM
Do you think that the thermostate has somthing to do with the v-tec???? cause I dont think the thermostate has anything to do with my v-tec not kicking on. anymore info please help......
Old Jul 16, 2005 | 01:58 PM
BlueIntegraBoy's Avatar
Default Re: (allmotor_guys)
Maybe your temperature sensor went out? Even if the thermostat is stuck open, it will take longer for the engine to reach normal operating temperature.
Old Jul 16, 2005 | 02:03 PM
Absubtle's Avatar
A number of sensors could cause this. But you really need a CEL, check engine light, so you and us can sort thru it. COuld be VTEC pressure switch, which I found is easily bypassed, VTEC soleniod (most often bad connection or low oil level, or Coolant temp sensor which is located below the distributor area. Is it saturated w/ oil. I know this is pretty common w/ B-Series engines.
Absubtle
PA
Old Jul 18, 2005 | 07:26 PM
Default Re: (Absubtle)
The last time my engine check came on I check. It was my o2 sensor and I got that fix. my motor is not throwing any type of code at this time that why I'm so clue less on why my v-tec dont work... anymore info please help???????????????
Old Jul 18, 2005 | 07:30 PM
PRcivicHB's Avatar
How do you know your VTEC is not engaging??
Old Jul 19, 2005 | 10:10 AM
Default Re: (PRcivicHB)
I know that my v-tec is not engaging because it come on for about ten minute. Then after that it dont kick on anymore.........
Old Jul 19, 2005 | 12:29 PM
jmcmil6's Avatar
yeah then it definetly sounds like an issue w/ ur coolant temp sensor.. or the wiring.. the sensor is like 30bucks, try replacing that and see if that fixes ur problem--- there are several things the vehicle looks at before engaging vtec... "maybe" for some reason ur sensor is reading more than it should, allowing u to engage when the vehicle is actually cold, but when warm, making it look like temps are too high, thus not allowing vtec... good luck
Chpwhtek
Mar 19, 2012 04:48 PM
supramr2
Jan 19, 2008 05:34 PM
dre23
Nov 13, 2005 12:35 PM
Nsane1
Jun 12, 2004 04:47 PM
accord5speed
May 9, 2002 08:09 AM
