Will dealer give shit about short shifter if tranny has problem?
Old Jul 14, 2005 | 05:57 AM
Blaziniflo's Avatar
Default Will dealer give **** about short shifter if tranny has problem?
Based on your experience.
Old Jul 14, 2005 | 11:11 AM
Kal's Avatar
Kal
Default Re: Will dealer give **** about short shifter if tranny has problem? (Blaziniflo)
It really just depends on your dealership's stance on aftermarket parts/import modification...
But, yes, they'll probably give you a problem -- stating that you could have misshifted and stuff.
Old Jul 14, 2005 | 04:30 PM
whiteDCfiver's Avatar
The dealer will use any excuse it can to have you pay outa pocket
Old Jul 14, 2005 | 05:25 PM
cranny's Avatar
24.224.233.247
Default Re: Will dealer give **** about short shifter if tranny has problem? (Captin Bodussy)
took the words right outa my mouth captain , nuff said.
Old Jul 14, 2005 | 07:59 PM
coupe99vtec's Avatar
friend of mine had to pay his own axle bearings after puttin on new wheels. another had to pay for AC cuz the pulleys were changed...
they f*ck you over as hard as they can
Old Jul 15, 2005 | 05:49 AM
Morning Call's Avatar
yeah i can see a short shifter ******* you over at the dealer when it comes down to tranny problems...
mainly because a tranny can only shift so fast.. and u can max that speed with a normal shifter.. a short shifter is just gonna end up forcing your tranny into gear... which is bad
Old Jul 16, 2005 | 11:35 AM
BlackSage's Avatar
most of the people in this thread have been denied service because they have mods that effect related parts. For example a short shift should have anything to do with your alternator going out. I would say if you want to go in for a tranny problem you should either put in your original shifter or grab your ankles
Old Jul 16, 2005 | 11:58 AM
vanos_pusha's Avatar
Default Re: Will dealer give **** about short shifter if tranny has problem? (BlackSage)
does your dealership know anything about our cars?!?! if not, don't tell them!!
my dealership is sto0pid! They didn't even realize i had a aftermarket header!!!
Old Jul 16, 2005 | 03:00 PM
Stewie's Avatar
Default Re: Will dealer give **** about short shifter if tranny has problem? (single_cam_ham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by single_cam_ham &raquo;</TD></TR><TR><TD CLASS="quote">does your dealership know anything about our cars?!?! if not, don't tell them!!
my dealership is sto0pid! They didn't even realize i had a aftermarket header!!!</TD></TR></TABLE>
and you let these guys work on your car?
Old Jul 16, 2005 | 03:08 PM
Stewie's Avatar
Default Re: (rentacar4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rentacar4dr &raquo;</TD></TR><TR><TD CLASS="quote">friend of mine had to pay his own axle bearings after puttin on new wheels. another had to pay for AC cuz the pulleys were changed...
they f*ck you over as hard as they can</TD></TR></TABLE>
These are problem that don't typically happen with similar cars during the warranty period. If I was the service manager, and someone came in with aftermarket wheels requesting warranty work for a wheel bearing in which case the aftermarket wheels had greater offset than stock, you'd bet that customer would be paying for all work.
And for the other case, I would also charge the customer to replace a compressor if had aftermarket pulleys. I can definitely see how pulley could contribute to a broken compressor.
Both were very reasonable for charging your friends.
Old Jul 16, 2005 | 10:28 PM
B16aDasher's Avatar
Default Re: (Stewie)
I had one dealer try to get out of fixing my tranny because i had an aftermarket headunit. They fixed it, after i threw a fit tho. yet, i took my car to another dealer with rims,suspension, exhaust and CIA. And the fixed another problem with the engine, plus they could stop telling me how awsome my car looked. So it just depends on where you go.
Old Jul 17, 2005 | 12:47 AM
BlackSage's Avatar
Default Re: (B16aDasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16aDasher &raquo;</TD></TR><TR><TD CLASS="quote">I had one dealer try to get out of fixing my tranny because i had an aftermarket headunit. </TD></TR></TABLE>
Thats the stuff I am talking about. That is crazy.
Modified by BlackSage at 10:18 AM 7/18/2005
Modified by BlackSage at 10:19 AM 7/18/2005
Old Jul 17, 2005 | 12:42 PM
hk2ronin's Avatar
If u dnt want to grab your ankles at the dealership go to the sema website and do some research. There is a federal law stating that dealerships cannot deny a warrranty unless they can prove that the specific performance part caused the damage. They probaly won't do this because they have to do a expensive test. THe law is on your side my friend so do the research and use the law to your advantage. I can't believe they still want to mess with our warrantys after the civic nation commecials had hundreds of hondas with turbos, intercoolers, rims, bodykits the whole shabang(did anyone see those commercials?)
Old Jul 18, 2005 | 12:10 PM
SpoonyDC5's Avatar
Default Re: (hk2ronin)
Yes they will.......i worked at acura a while ago and after i purchased my RSX-S the first thing all the techs told me was to NOT get a short shifter..... apparently dont get the comptech either ,they all tend to mess up the tranny synchros , soo id say YEP they will pitch a fit...
+honda_monkey+
14
Jan 18, 2010 06:55 PM
Mario.
Dec 21, 2004 04:16 PM
Spade
35
May 11, 2004 01:07 PM
Art701
Mar 4, 2003 06:55 PM
2k1TypeR0610
Feb 11, 2002 06:27 AM
