Putting cams 0,0 with milled head...
Hello guys, I'm a little confused, I was reading all the milled head threads that I found in the search area.
I have a JDM DC2 ITR with 11.1:1 CR and I milled the head 0.050" and put the Spoon headgasket. All said that 0.012" milled has to advanced 1 degree So doing the math I have 0.056" (with h/gasket) milled, I have to put in the cam gears (I have Toda cam gears) intake +4.5 exhaust +4.5 to be 0,0 in the crank???
Or I'm wrong here?
Or I'm wrong here?
bump for a topic that should be more thoroughly discussed and understood.
from what i have read on this forum, milling the head retards the timing, so you want to advance the cams. what if you compensate for some head milling with a thicker head gasket, do you still have to advance the cams?
1 DEGREE PER 12 THO
so yes 50 tho is like 5 degrees
how do u know that one mark on ur toda's is 1 degree, and is it 1 degree@crank or 1 @ cam?
i bet ur crap feels so sluggish right now!~!!
clay before u advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ( o )( o ) »</TD></TR><TR><TD CLASS="quote">bump for a topic that should be more thoroughly discussed and understood.
from what i have read on this forum, milling the head retards the timing, so you want to advance the cams. what if you compensate for some head milling with a thicker head gasket, do you still have to advance the cams?</TD></TR></TABLE>
you do not, its liek adding deck height back.
dont ASSUME where the cams should go with gear marks
BE SURE they go where they do, by degreeing them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm »</TD></TR><TR><TD CLASS="quote">1 DEGREE PER 12 THO
clay before u advance</TD></TR></TABLE>
12 thousandth is 1 degree on the crank o @ cam?
VtecDA9
Oct 2, 2003 12:52 PM
