front or rear sproket
If I remember correctly the kits designed for acceleration go one down in the front and two up in the rear.
Most sprocket companies offer packages both sprockets and a chain. Look for the quick acceleration kit and check out the specs as far as tooth config.
Going down one tooth in the front is equivalent to about 2 up in the rear if I remember correctly.
Steven
Steven
Changing the front is way more noticable than changing the rear. Rear is more like fine tuning, where as going a tooth or two smaller in the front is a huge difference.
ok thanks then most likely i'm gonna go with one or two smaller in the rear and ama see how that works out later on i'll prob go with a kit thanks for your help guys
