aluminum pipe for exhaust piping?
Old Jul 13, 2005 | 10:29 PM
GSteg's Avatar
Default aluminum pipe for exhaust piping?
How well will the Aluminum 6061-T6 hold up to the exhaust's heat? I'm welding together my own pipe for my muffler and I need something that isn't expensive (this is best i've seen for the price)
thanks!
Old Jul 14, 2005 | 05:51 AM
beepy's Avatar
Default Re: aluminum pipe for exhaust piping? (GSteg)
At least one person has been using an aluminum exhaust for a few months with success.
I still contend, however, that the major issue will be fatigue. Aluminum has no fatigue limit, the exhaust has a lot of vibration and aluminum's properties just get worse when heat is applied. At about 1000°F aluminum starts to creep, so of course it is no good for the downpipe.
Old Jul 14, 2005 | 06:34 AM
weiRtech's Avatar
OG Fabricator
Default Re: aluminum pipe for exhaust piping? (beepy)
ms would be the cheapest, why not just use that? i don't think i'd use aluminum for my exhaust... if it was a good idea, don't you think everyone else would be doing it already? i've never seen an aluminum exhaust, aluminized steel- yes.
Old Jul 14, 2005 | 07:31 AM
beepy's Avatar
Default Re: aluminum pipe for exhaust piping? (weirRacing)
Damn the search feature sucks. I know there is a 4" aluminum exhaust post on here, but can't find it.
Old Jul 14, 2005 | 08:57 AM
HighPerformance's Avatar
Geoff @ Full Race is running a 4" aluminum exhaust I believe on his street car. I think there is a post about it in the FI section as well.
Old Jul 14, 2005 | 11:03 AM
GSteg's Avatar
this if more specifically for making a testpipe. I don't have the skills to make a full pipe from the engine all the way back
I guess I'll just go with the 7ft steel at JCwhitney?
though I don't need all 7 feet. 3 feet at most
Old Jul 14, 2005 | 12:32 PM
Default Re: (GSteg)
what size piping diameter do you need?
I have a stick of 3" OD mild steel that 10' long. If you need a small piece let me know.
vtecths@***.net
Old Jul 14, 2005 | 01:27 PM
GSteg's Avatar
I am looking at 2.25"-2.5"
3" is too big.
Old Jul 14, 2005 | 02:29 PM
99_GS-T's Avatar
Look in the phone book for metal supply places local to you. You'll probably find a local place that will sell you just the length you need and at a better price then almost anywhere on the net.
Old Jul 31, 2005 | 02:49 PM
Tad's Avatar
Tad
Default Re: (99_GS-T)
I love the idea of weight savings with using aluminum,
but like you guys said, it's not tough like steel.
I mean, maybe if you used it only after the downpipe, it'd be ok.
I'd be worried about the exhaust hitting stuff too so you'd want to build it
carefully so it doesn't hang too low.
Anyone know if you can weld steel to aluminum and visa versa??
Old Jul 31, 2005 | 03:39 PM
ManBearPig4silly's Avatar
You cant weld steel to alum as far as I know.
CRX Si69
Welding / Fabrication
Apr 17, 2012 03:08 AM
baulum
47
Oct 17, 2007 05:46 PM
rough_draft
Nov 17, 2004 06:07 AM
leeit2me
Nov 15, 2003 09:49 AM
Boosted LS
Jul 9, 2003 07:12 PM
