FS: B18A1 Block
Old Jul 13, 2005 | 09:23 PM
B18 CYA's Avatar
Default FS: B18A1 Block
-The engine is a B18A1block
-P30 JDM B16A pistons
-micropolished crank
-new main bearings
-new rod bearings
-new thrust washers
-new piston rings
-new front and rear seals
-new type r vtec oil pump
-new vtec water pump
The block will also come with the coolant passage, oil pressure sensor, thermostat housing, oil catch can and the crank pulley.
Block has been assembled recently and has 0 miles on it.
$899
B18 CYA
Jun 7, 2005 06:12 PM
B18 CYA
Canada (Sales)
Jun 4, 2005 08:01 PM
B18 CYA
Apr 22, 2005 05:15 AM
B18 CYA
Apr 22, 2005 05:14 AM
