FS: B18A1 Block
-The engine is a B18A1block
-P30 JDM B16A pistons
-micropolished crank
-new main bearings
-new rod bearings
-new thrust washers
-new piston rings
-new front and rear seals
-new type r vtec oil pump
-new vtec water pump
The block will also come with the coolant passage, oil pressure sensor, thermostat housing, oil catch can and the crank pulley.
Block has been assembled recently and has 0 miles on it.
$899
-new main bearings
-new rod bearings
-new thrust washers
-new piston rings
$899
B18 CYA
Jun 7, 2005 06:12 PM
