Spark plugs for the R
Old Feb 16, 2002 | 01:49 PM
silvercivicsir's Avatar
Default Spark plugs for the R
Does anybody know the correct spark plugs for the type R ? I think the deal may of put in Gsr plugs in the R.. since I just got off the ngk website and it says the ones they put it are for a GSR.. according to the box they gave me. [ when i asked for my old plugs back ]
Old Feb 16, 2002 | 05:54 PM
JPP's Avatar
JPP
Default Re: Spark plugs for the R (silvercivicsir)
NKG PFR6G-11
Old Feb 16, 2002 | 07:11 PM
JSIR's Avatar
New User
Default Re: Spark plugs for the R (JPP)
JPP, I always thought the ITR uses heat range 7 in NGK plugs, you list it as a 6 , in the plug you list, also the gap is 1.3mm so the plug code should end in a 13 if they are pre-gapped factory plugs. You can use an 11 plug and just gap it to 1.3mm though. .
Old Feb 16, 2002 | 09:51 PM
JPP's Avatar
JPP
Default Re: Spark plugs for the R (JSIR)
The number I listed is the stock spark plug in the ITR. The gap recommended is definitly 1mm to 1.1mm (as writen under the hood and in the service manual). The B18C1 (GS-R) has a recommended spark plug gap of 1.3 mm.
Old Feb 18, 2002 | 01:41 AM
SnyperSiR's Avatar
Hahaha... seems like I'm chasing your posts a little around this board, Joey!
I need to change the plugs, moving away from Bosch Plat +4. What would you recommend and what about gapping? TIA
Old Feb 18, 2002 | 02:36 AM
typer694's Avatar
New User
NGK PFR6G-11 or DENSO PK20PR-L11
blackj30_a
Jun 30, 2015 03:06 PM
Calean007
May 9, 2005 07:04 PM
EL'ation
Aug 5, 2002 01:12 PM
