Head Gaskets and Sleeved Blocks: Lets Discuss
Old Jul 13, 2005 | 08:06 PM
asubennett's Avatar
Default Head Gaskets and Sleeved Blocks: Lets Discuss
Ok, I am sure at one point or another we have all come across a head gasket issue. Something I have discovered is that every time I have had a gasket failure the gasket was the same size as the bore. Most recently I have switched to a gasket that is slighty bigger than the bore and have had zero problems at all. Is this just a coincidence?
What do you all feel works best for sealing a head gasket on a large bore motor, 85mm-87mm on a B Series motor or 89mm on an H22. I just want to here others experiences, thoughts on this subject.
Cliff Notes:
When I use 86mm bore-86mm HG I get problems
86mm bore- 86.5mm HG No Problems
Old Jul 13, 2005 | 10:25 PM
Toxidomask's Avatar
Default Re: Head Gaskets and Sleeved Blocks: Lets Discuss (asubennett)
sounds intresting... why would this be? anyone can shine a light to this?
Old Jul 13, 2005 | 11:42 PM
WickedSol's Avatar
Default Re: Head Gaskets and Sleeved Blocks: Lets Discuss (Toxidomask)
Headgasket failure in most cases happen when the head studs aren't torqued to spec. When the head isn't resurfaced correctly, or even the block isn't decked as well...I've also seen aftermarket headgaskets fail to seal up because of a manufactures defect...
I recommend using only OEM gaskets on Honda motors...if you went big bore, just have the OEM gasket bored to your spec...
Old Jul 14, 2005 | 12:20 AM
asubennett's Avatar
Default Re: Head Gaskets and Sleeved Blocks: Lets Discuss (SpdImge415)
My gasket is just fine right now and it is a cometic. This is not the debate I am trying to have. I want to know about what makes, if at all, an gasket that is larger than the bore more resistant to failure.
Both my block and head were machined. They are as flat as they come. The issue comes from the limited amount of material trying to seal.
Old Jul 14, 2005 | 12:50 AM
WickedSol's Avatar
IMO...Its just coincidence...
Old Jul 14, 2005 | 09:53 AM
X-Mazda 3 Racer's Avatar
Sometimes if the gasket hangs into the bore a little, it has the ability to get really hot in the over hang area. Sometimes this can cause a problem, sometimes it won't. It all deopends on the BTU's of the combution really, and the timing. I NEVER have any part of any gasket hang into the combustion chamber, if not for anything else than peace of mind.
And to let you know, I never have gasket issues with the motor I build.
Old Jul 14, 2005 | 06:44 PM
asubennett's Avatar
Default Re: Head Gaskets and Sleeved Blocks: Lets Discuss (GoldenEagleMfg.com)
So it is not a coincidence then. :-) Thanks. I will stick with ordering my gaskets a little larger than the bore.
Muckman
Oct 22, 2011 10:32 AM
JLHDOHC
Feb 12, 2006 08:44 PM
Lmgrcivic
Feb 6, 2005 04:55 PM
boostedel
Apr 6, 2003 09:11 AM
