Idle Hesitation with Hondata
Old Jul 13, 2005 | 05:15 PM
TurboTeG4's Avatar
Default Idle Hesitation with Hondata
Im running a modified map for my gsr turbo, got the a/f for idle pretty good but when you tap the throttle very very lightly the rpms drop like 200 before picking up. What do I modify to stop this hesitation from idle position? Im running 440 injectors, etc.
Old Aug 14, 2005 | 04:03 PM
TurboTeG4's Avatar
Default Re: Idle Hesitation with Hondata (TurboTeG4)
Finished tuning this problem is still here, especially when cold, when warmed up it might not be doing it
Old Aug 14, 2005 | 07:16 PM
drdisco69's Avatar
Is the A/F going rich or lean when it does it? It might not have enough tip in fuel enrichment, or it might have too much. Can you even adjust that with Hondata, I dunno...
Old Aug 14, 2005 | 07:46 PM
TurboTeG4's Avatar
Default Re: Idle Hesitation with Hondata (drdisco69)
My injector multiplier is at 0.7 and throttle tip at 0.7, do I raise the throttle tip to say 0.8 and does this go in the rom when real time emulating?
Old Aug 16, 2005 | 06:03 PM
TurboTeG4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">My injector multiplier is at 0.7 and throttle tip at 0.7, do I raise the throttle tip to say 0.8 and does this go in the rom when real time emulating?</TD></TR></TABLE>
eg:R
Mar 26, 2006 10:23 AM
inspyral
Jul 6, 2005 09:46 PM
TurboTeG4
Jun 29, 2005 09:25 PM
Black R
63
Feb 25, 2005 12:19 PM
