running > died > Code 8 TDC = coil?????? HELP (searched)
Old Jul 13, 2005 | 03:06 PM
FalkenSiR's Avatar
Default running > died > Code 8 TDC = coil?????? HELP (searched)
So I was driving and it just stalled. It won't even crank. Relay is not an issue so that is out of the picture. If you push-start it, it starts fine. But it throws code 8 TDC. I followed all my MPFI-converted wires and some were dirty as hell. One was loose but I redid them all. I stripped them and connected them together but nothing. Reset ECU, nothing.
I'm stumped. I searched but it's always under different circumstances. I took my dizzy cap off and everything is clean. Nothing unusual. Please help my guys, i'm trying to get rid of this car and now this happens.
Old Jul 13, 2005 | 03:36 PM
FalkenSiR's Avatar
Default Re: running > died > Code 8 TDC = coil?????? HELP (fast88std)
bump to get my car running!!!!!!!
dizzy? coil?
Modified by fast88std at 5:08 PM 7/13/2005
Old Jul 13, 2005 | 08:18 PM
FalkenSiR's Avatar
bump
Old Aug 1, 2005 | 08:41 AM
Scoupe's Avatar
same propblem overhere
I did a search on this problem and found the question 3 times..
but NO asnwer..
on whole HT no specialist's know what the deal with this? hard to believe ..
Old Aug 1, 2005 | 09:45 AM
d15civ's Avatar
Default Re: running > died > Code 8 TDC = coil?????? HELP (Scoupe)
same thing happens with my car.
i can reset the ecu, and nothing will come up.
if i plug in my vafc, start it. nothing comes up. but soon as i try and start it, it flashes code 8 and will not start.
its weirdhttps://honda-tech.com/zeropost?cmd=reply&id=16837927#
https://honda-tech.com/zero...37927#
Old Aug 1, 2005 | 10:36 AM
Skinflute22's Avatar
check the faq's they got all the codes and how to fix um in there
jdmturboitr
Jan 20, 2010 07:22 PM
channy
Jan 12, 2006 02:50 PM
aown61
Sep 26, 2005 09:56 AM
SunkistRex
Apr 12, 2004 10:27 AM
Blaze45
Jul 2, 2003 07:58 PM
