Car started to overheat? What gives?
Old Jul 13, 2005 | 02:24 PM
vtec.dc2's Avatar
Default Car started to overheat? What gives?
updates: replaced thermostat rated 180F and problem still persist
I pulled over as stock gauge went past center.. i'm at 90k miles right now, original 2001 cooling system components unless dealership replaced them at 60k service..
i was driving at mid rpm and after 20-30 minutes it started to climb past center, i switched a/c to heat and pulled over, the fan was working, so i continued to drive.. i had this similar problem while wastegate piping leak, but everything is fine now.. what gives?
Modified by vtec.dc2 at 6:42 PM 8/2/2005
Old Jul 13, 2005 | 03:13 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Car started to overheat? What gives? (vtec.dc2)
Bad thermostat?
Old Jul 13, 2005 | 04:01 PM
meat's Avatar
Replace your radiator and thermostat.
Old Jul 13, 2005 | 04:31 PM
vtec.dc2's Avatar
Default Re: Car started to overheat? What gives? (meat)
i'll start with thermostat.. my rad. doesn't leak.. does it really needs to be replaced at 90k?
Old Jul 13, 2005 | 04:37 PM
Ricky Rojales's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">i'll start with thermostat..</TD></TR></TABLE>
Thermostat make more sense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">my rad. doesn't leak...</TD></TR></TABLE>
You answered your own question. But check your hoses and clamps too.
Are you losing fluid?
Old Jul 13, 2005 | 04:41 PM
vtec.dc2's Avatar
Default Re: Car started to overheat? What gives? (=p)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =p &raquo;</TD></TR><TR><TD CLASS="quote">
Are you losing fluid?</TD></TR></TABLE>
no. fluid doesn't leak
only other time this happend is when my wastegate pipe was loose and i was in hot weather + traffic last year, today it happend again except i was hwy driving + heat..
Old Jul 13, 2005 | 05:42 PM
Mythias's Avatar
Any excessive collection of coolant in the reservoir?
Old Jul 13, 2005 | 06:01 PM
Mythias's Avatar
Default Re: Car started to overheat? What gives? (skandalintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skandalintegra &raquo;</TD></TR><TR><TD CLASS="quote">can a fuel gauge and accessories in the tank be replaced at a cheap(er) cost? mine's crazy.. when i turn right, it dips way down, almost to E if im at center, and if i take a left, it goes to F... and when it goes to E and i can still get a good 50 miles off of it.</TD></TR></TABLE>
WTF? Damn hijacker.
Old Jul 13, 2005 | 06:06 PM
vtec.dc2's Avatar
Default Re: Car started to overheat? What gives? (mythias)
nope.. i check fluids just about every time i drive.. i tried driving around again on hwy.. nothing happned, if this happens agan, i guess i'll replace thermostat
Old Jul 13, 2005 | 06:09 PM
vtec.dc2's Avatar
Old Jul 13, 2005 | 06:11 PM
skandalintegra's Avatar
well i figured since it was a similar object to the thermostat.. at least the gauge part... id keep the forums clean.
Old Jul 13, 2005 | 06:12 PM
blahhhhhhhh's Avatar
sounds like a thermo like everyone else says.
Old Jul 13, 2005 | 06:35 PM
TypeGSR196's Avatar
Default Re: (blahhhhhhhh)
hey bro chk the ac condensor, it might be clogged up of dirt........it happened to me a few weeks ago..........my temp started to go up, I checked all possibilities, the car was leaking anti-freeze from the rear-bottom part of engine.......I thought it was the coolant piping, but it would stop............
I put the car on a lift & noticed the dirt, I used an engine cleaner spray & a high pressure hose..........happilly ever after
I hope it helps you
Old Jul 13, 2005 | 06:48 PM
vtec.dc2's Avatar
Default Re: (TypeGSR196)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeGSR196 &raquo;</TD></TR><TR><TD CLASS="quote">hey bro chk the ac condensor, it might be clogged up of dirt........it happened to me a few weeks ago..........my temp started to go up, I checked all possibilities, the car was leaking anti-freeze from the rear-bottom part of engine.......I thought it was the coolant piping, but it would stop............
I hope it helps you </TD></TR></TABLE>
i'll check it as well, but... how a/c condesor affect coolant temps?
Old Jul 14, 2005 | 05:30 AM
TypeGSR196's Avatar
Default Re: (vtec.dc2)
a/c condensor sits infront of the radiator, so being clogged up affects the flow of air to the radiator........
hey its something that bugged me out but cleaning it, cleared my problem
Old Jul 14, 2005 | 06:03 AM
ITRiWISH's Avatar
Hey, If you are interested I have a Brand new Spoon Thermostat that I never got to put in my Teg. It opens at a lower temp. than the stock ones and allows for earlier cooling. (My car was "modified" by a guy who didn't see me or the yield sign)
And if you are interested I also Have a brand new water pump, timing belt, and tensioner spring.
SPOON!!!
Old Jul 14, 2005 | 06:04 AM
ITRiWISH's Avatar
Default Re: Car started to overheat? What gives? (ITRiWISH)
Oh yeah, Thats a Type R water pump and belt. All with the Honda logos and Honda cast into the pump... If you are interested I can send some Pictures...
On a side note, Even if you have the right of way, slow a little and check for Idiots!!!!!!!!!!!!!
Old Jul 14, 2005 | 06:16 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">I pulled over as stock gauge went past center.. i'm at 90k miles right now, original 2001 cooling system components unless dealership replaced them at 60k service..
i was driving at mid rpm and after 20-30 minutes it started to climb past center, i switched a/c to heat and pulled over, the fan was working, so i continued to drive.. i had this similar problem while wastegate piping leak, but everything is fine now.. what gives? </TD></TR></TABLE>
Maybe your car was on fire?
Definitely sounds like a sticky thermostat. My old prelude did that, I nearly pegged the thermostat a couple of times, then it magically went away for many months.
If it does it again, see if your radiator is scorching hot or not. This might be easier said than done, since it will be hot, but it's hard to tell the difference by hand between 150F and 220F
-Chris
Old Jul 14, 2005 | 07:40 AM
200cs's Avatar
You may also want to check the accuracy of your indicator. If you have an an OBD2 scan tool you can check the output of the control sensor as compared to the indication sensor. Your engine may not be overheating it may be an indication problem.
Old Jul 14, 2005 | 08:08 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Car started to overheat? What gives? (200cs)
I'm gonna go with thermastat.
Old Jul 15, 2005 | 09:18 PM
xanctus's Avatar
check the thermostat sensor, I had this problem once...and if your car still under warranty, you might get it fixed free...at least that waht happened to me
Old Jul 29, 2005 | 02:48 PM
vtec.dc2's Avatar
update:
replaced thermostat autozone thermostat. few to choose from, i went with more expensive one and 180 degree instead of factory 195.. the hose wouldn't come off, but i managed to replace thermostat without relocating anything..
so far so good, i think this may even play a role in how my oil pressure was lower.. good thing i was using thick 15w50 and 20w50.. i wonder if any damage was done if it went towards middle for 15-30 seconds, and passed it a bit for few seconds.. this happend 2-3 times
Old Jul 29, 2005 | 03:11 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">so far so good, i think this may even play a role in how my oil pressure was lower.. good thing i was using thick 15w50 and 20w50.. i wonder if any damage was done if it went towards middle for 15-30 seconds, and passed it a bit for few seconds.. this happend 2-3 times</TD></TR></TABLE>
No chance, I wouldn't worry about it. I've run it hotter than that. 3/4ths of the way up, turbo track day, 85 degrees, no oil cooler (or temp gauge). Yikes.
I also nearly pegged my Prelude's temp gauge once, sticky thermostat.
If your radiator fluid didn't overflow, j00're cool!
Old Jul 29, 2005 | 05:45 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: Car started to overheat? What gives? (Chris F)
FYI, oem honda ones start the flow at 78 degrees C which is 172 F
Old Jul 31, 2005 | 02:02 PM
vtec.dc2's Avatar
Default Re: Car started to overheat? What gives? (MugenHonda)
****.. i had opportunity to get one at 170.. damn it.. i was wondering why temps were not showing lower than normal with it being 15 degrees lower..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">FYI, oem honda ones start the flow at 78 degrees C which is 172 F
