Part #: For ITR Differential Bolts (Ring Gear to Diff)
Putting an ITR LSD and ATS into my b16 this weekend. From what I can tell, I need to replace the diff bearings and the differential bolts. Does anyone have the part number of the differential bolts?
TIA
TIA
Damn it. is that the same part number as for a 99-00 Si?
This post is confusing me: http://forums.clubsi.com/showf...age=0
All the other research I have done indicates that my stock bolt should work fine if I'm matching up an ATS Final Drive Kit for a b18 to an ITR LSD.
I just don't understand why you folks can't look part #'s up yourselves. They're all online!
Acura - http://www.acuraparts247.com
Honda - http://www.slhondaparts.com
Thanks for the link.
Looks like there are two different versions:
90017-p80-j00 - This is the bolt that is used on the ITR
90017-689-000 - This si the bolt used on non-lsd equipped GSRs, and Si's.
I'm guessing that the 90017-p80-j00 bolts are the longer ones I need.
10, 90017689000, 90017p80j00, b16, bolts, differential, gear, honda, integra, itr, number, oem, part, ring, typer
