Valve Guides
Old Jul 13, 2005 | 09:10 AM
WVTURBOCRX's Avatar
Default Valve Guides
What are most of the HT team using for the Valve guides?
The is for a B16A boosted application, I see the Bronze ones and the replacements for stock but what does everyone think. Performance and cost.
Old Jul 13, 2005 | 09:17 AM
PrettyLude's Avatar
bronze will need to be replaced often, stock will be fine, are you referring to the ferrea ones?
Old Jul 13, 2005 | 09:23 AM
WVTURBOCRX's Avatar
Default Re: (PrettyLude)
No they were http://www.honda-performance.com/guides.asp
So the stock ones will hold up better?
Old Jul 13, 2005 | 10:02 AM
slomofo's Avatar
GDD Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">bronze will need to be replaced often, stock will be fine, are you referring to the ferrea ones?</TD></TR></TABLE>
Uh oh, I just threw bronze guides in last month.
Old Jul 13, 2005 | 10:31 AM
WVTURBOCRX's Avatar
Default Re: (slomofo)
So is that the consencese that they die faster?
Old Jul 13, 2005 | 01:24 PM
ildknyli's Avatar
Default Re: (WVTURBOCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WVTURBOCRX &raquo;</TD></TR><TR><TD CLASS="quote">So is that the consencese that they die faster?</TD></TR></TABLE>
Would also like to know
Old Jul 15, 2005 | 12:23 PM
WVTURBOCRX's Avatar
Default Re: (ildknyli)
Bump for more feedback
Old Jul 15, 2005 | 03:44 PM
Fkned's Avatar
I don't understand how people say bronze guides wear faster then iron guides,I've never seen this in any application ever and that goes for heads used in Nascar-Busch/All Pro/Pro Stock,etc...for an entire season.The material is harder then iron and should wear better then iron if the guide clearances are correct.I have seen many cases where a iron guide is worn into an oval shape but never w/a bronze guide have I seen this,and I'm talking about pushrod motors turning 8-9k w/much higher side loads on the guides then any import head has.
I feel the Ferrea guides are the best for Hondas imo,the tapered tips are the best flowing I've seen and they are of impeccable quality.
Old Jul 16, 2005 | 06:34 AM
WVTURBOCRX's Avatar
Default Re: (Ed's Racing Heads)
Great feedback, I agree.
Old Jan 14, 2006 | 11:57 AM
djnikko's Avatar
So the valve guides can deform with the extra heat caused by forced induction or higher RPM?
When should I look to change them out, 200hp? 300hp? 400hp? or is that irrelevant.
Thanks
Natural Aspirations
37
Dec 18, 2007 04:25 AM
wrestler72
Sep 5, 2007 04:56 PM
neofreak
Jul 1, 2007 12:04 PM
ACrite3404
10
Sep 13, 2006 10:02 PM
tommy.
10
Mar 28, 2006 09:22 AM
