dpi to mpfi dist. question
Old Jul 13, 2005 | 07:28 AM
89cmutr's Avatar
Default dpi to mpfi dist. question
Yeah i know old swap. I have searched many treads. When doing the dpi to mpfi do you need to swap to the si dist. Some say that you need to, and some are just not clear about it at all. If you do need to change to an si, is there more that you need than a dist. and harness side of the plug?
Old Jul 13, 2005 | 07:41 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: dpi to mpfi dist. question (89cmutr)
Yes,you need the MPFI distributor as it has an extra sensor
to trigger the injectors..
You need the Si type harness plug or you can use the DPFI style plug
on the Si distributor..
goldhatchi
Jun 25, 2009 07:05 PM
801ef
May 30, 2008 09:03 AM
thedudefromjerz
Feb 20, 2008 08:53 AM
.Grimace
Jan 3, 2007 11:19 AM
Kilohead36
Oct 19, 2003 10:48 AM
