Making my own harness, needs some stuff
Old Jul 13, 2005 | 05:32 AM
ne3ek's Avatar
Default Making my own harness, needs some stuff
Well Im doing an obd1 conv and using some obd2/obd1/obd0 stuff so I want to just make a custom harness, I've made one before but I need this one to be realllllyyyyyy clean.
I want to know if there is some where i can buy the honda pins and just crimp them myself
I also want a place that sells really good connecters/shrink tube/loom so i can buy up all this stuff. thanks
Old Jul 14, 2005 | 05:03 AM
ne3ek's Avatar
Default Re: Making my own harness, needs some stuff (ne3ek)
Old Jul 14, 2005 | 08:06 AM
HumanResource's Avatar
For the Plugs i go to the junkyard and cut off the chassis harness plugs off with enough wire length (about 5"-7")
for the ECU plugs, i do the same just open up the ECU and dremel off the plugs
heatshrink i go to the local electronics store and pick up the 3M stuff But I'm starting to used this other cheaper stuff and it works just as fine.
solder i used regular resin base from Radio Snack
Old Jul 14, 2005 | 11:31 AM
Fobtions's Avatar
Default Re: Making my own harness, needs some stuff (HumanResource)
the cleanest thing to do is to depin all the plugs and insert them into the obd1 grey plugs.
i hate the way the obd0 green plug looks.
Old Jul 14, 2005 | 04:10 PM
ne3ek's Avatar
Default Re: Making my own harness, needs some stuff (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">the cleanest thing to do is to depin all the plugs and insert them into the obd1 grey plugs.
i hate the way the obd0 green plug looks.</TD></TR></TABLE>
you must be talking about the fire wall/shock tower plugs right? I never thought about that it's a great idea! I'm probably gonna tuck em anyways but I think i'll do that 1st.
thanks for the advice guys
GlassHeadlights
10
Mar 4, 2010 12:42 PM
JUN.
Mar 28, 2008 06:00 AM
amy
May 22, 2006 03:04 PM
Brian_92GSR
Jan 17, 2005 06:41 AM
Kwuaymaikrup
Aug 8, 2003 01:27 PM
